LS/VTEC Knock Sensor
Old Aug 17, 2002 | 07:37 AM
Boostless97Lude
Guest
Posts: n/a
Default LS/VTEC Knock Sensor
ok, i have an LS/VTEC in my 95 Teg LS, well, the whole time i have been through 3 ECUs so far, a bunk P28, a 92 GS-R, and a P72, well, each had a CEL, and i thought it was for the IAT sensor. i finally did some wire chasing and fixed that, and now as i'm drivin down the road it comes on again and i shows knock sensor.
My question is, is there a away to safely ground out that wire so that it doesn't read it, or another way to wire it to bypass that sensor. i have a P28 on the way that i will re-chip, but until then, what chould i do???
[Modified by Boosted97Lude, 11:38 AM 8/17/2002]
Old Aug 17, 2002 | 09:26 AM
lsvtec4door's Avatar
Default Re: LS/VTEC Knock Sensor (Boosted97Lude)
if ur using a p28 computer....the p28 is a knocksensorless computer...p28 computer dont register a knock sensor
Old Aug 17, 2002 | 07:42 PM
bullz's Avatar
Default Re: LS/VTEC Knock Sensor (lsvtec4door)
this might help LS/VTEC from C-Speedracing
Old Aug 17, 2002 | 08:56 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: LS/VTEC Knock Sensor (iLLestjr)
it doesn't really..... they're solution to the problem would involve me removing the block again.... plus i fabricated a different alternator bracket so it wouldn't work anyways
GSR-TRBO-DA
Aug 15, 2007 09:28 PM
kerby116
Feb 15, 2004 08:56 PM
BoostedSOHC
May 12, 2003 09:01 AM
Doctor CorteZ
Feb 7, 2002 04:45 PM
