will this swap work?
Old Aug 15, 2002 | 07:19 PM
acuraLSSE95's Avatar
New User
Default will this swap work?
Car is 95 LS auto.
take out auto LS tranny and it's components. Can I install a GSR tranny with all assemblies on an LS engine block? will it work? problems?
[Modified by acuraLSSE95, 4:21 AM 8/16/2002]
[Modified by acuraLSSE95, 5:08 AM 8/16/2002]
Old Aug 15, 2002 | 07:32 PM
Quik Chris's Avatar
Default Re: will this swap work? (acuraLSSE95)
Yeah, the only thing is, is putting in the master cylinder, the hydrolic lines, shift linkage and shifter, then the clutch pedal, but the answer is yes, it can be done.
Old Aug 15, 2002 | 07:48 PM
tC_Dragon's Avatar
Default Re: will this swap work? (Midori Shinkansen)
From my understanding ur also going to have to weld on a new tranny mount or something or else it rattles/vibrates. Thats wat i herd anywayz. But the swap is definitely doable... do a search.
Old Aug 15, 2002 | 07:55 PM
New User
okie, now I know that this swap is doable(LS auto to GSR tranny). my othre question is, after the swap is done. How does it compare to a LS auto to a LS manual tranny swap? How much is the gain?
LASTLY, since my 95LS auto tranny is OBDI, If I get a GSR tranny that is OBD2 will be be a problem converting?
[Modified by acuraLSSE95, 5:09 AM 8/16/2002]
Old Aug 16, 2002 | 04:44 AM
TEG98's Avatar
The manual transmission is not computer controlled.
Old Aug 16, 2002 | 04:54 AM
Davanca's Avatar
Default Re: will this swap work? (TEG98)
Yeah your right, the manual trans is not computer controlled, but his automatic one is which means he is going to have to change his ecu to a ls manual, or GSR ecu. I have a auto teg also and i once thought about swapping but once i found out i had to change a ecu, i just dropped the whole thing.
Old Aug 16, 2002 | 05:06 AM
fuguman's Avatar
New User
Default Re: will this swap work? (davanca24)
just get an aftermarket ecu, there are people selling some cheap if u cant get a hold of a stock ecu
Old Aug 16, 2002 | 07:11 PM
New User
why did you just drop the whole thing? what's wrong with switching ECU? too expensive? or just hard to find a manual LS or GSR ecu?
If I preferred neither one (LS or GSR) tranny and went with a Type R tranny with LSD with R ECU, how is that compared?
[Modified by acuraLSSE95, 4:11 AM 8/17/2002]
iheartDc2
Feb 2, 2006 02:05 PM
Pusha_T
Jun 19, 2003 04:22 AM
PhatboyNYC
Nov 6, 2002 07:47 PM
shotty527
Oct 30, 2002 06:39 PM
