help! cant shift.
Old Aug 14, 2002 | 09:01 PM
Bewkrazed's Avatar
Default help! cant shift.
i had just put in a new clutch and flywheel and it is really hard to shove it in gear. i have to like force it in with the clutch pedal fully depress. any idea wat is wrong? and the flywheel makes a whining noise like it is spinning really fast or somethin. oh yeai have a 96 LS with ACT heavy duty 6 puck with fidanza flywheel. wat could be the problem?
Old Aug 14, 2002 | 09:23 PM
Adampops's Avatar
Default Re: help! cant shift. (JDMWhore)
just an option: My 94 teg wouldnt go into gear and i found out it was the clutch master cylinder. I bleed the system and was able to drive around for a litte bit. But then i had to replace the cylinder.
KiasSan
Jun 27, 2012 02:21 PM
Terry36
Dec 7, 2011 04:48 AM
bombjester
Jan 27, 2010 03:19 PM
incubus
Apr 14, 2008 07:29 PM
preluder
Jun 24, 2003 07:00 AM
