this installation ok?
Old Aug 15, 2002 | 10:56 AM
csfalcon's Avatar
Default this installation ok?
When I was installing my short ram intake, I took a shortcut and now I am worried. There was a small rubber tube connected to the old intake pipe, I guess it contained connections to the coolant and other2 things. Anyway, I just took off that rubber tube and connected it to the new intake so the other 3 connections are unchanged. I hope you all know what I am talking about, cause I don't know the proper name of those tubes.
Please let me know if that is ok, thanks a lot. Will it affect my performace or break the engine, if yes, how should I correctly install it?
Old Aug 15, 2002 | 11:42 AM
mugenracer's Avatar
Default Re: this installation ok? (csfalcon)
there would have been one hose from the valve cover to the original intake pipe, all you do is connect that one to the new intake pipe. intake pipes have nothing to do with coolant, as long as the hose was originally going to the intake and is still going to the intake then your ok and needn't worry
Old Aug 15, 2002 | 12:17 PM
VTECorona's Avatar
Default Re: this installation ok? (mugenracer)
My intake came with 2 hoses, one to go from the aem pipe to the valve cover and the other one contains coolant. They just give you two hoses to get rid of that metal piece that contains both tubes.
Old Aug 15, 2002 | 12:20 PM
csfalcon's Avatar
Default Re: this installation ok? (97RedTegGSR)
Ohh, now I understand it. Thanks guys!
ilovemyh22
Dec 23, 2009 09:14 PM
8083tcman
Nov 29, 2008 09:24 PM
rbizzell30
Jun 13, 2008 03:06 PM
bavarian06
May 30, 2006 10:41 AM
Starrman85
Dec 17, 2002 08:45 PM
