Skunk2 mani. users....
After having my new intake manifold for almost a year I FINALLY got off my **** and installed it today. The performance is awesome.... all in the top end, but now I have a whistling sound coming from the t/b. I have checked all connections and have no leaks. It does idle alittle high also. Along with the mani. I have a new JDM ITR t/b and ITR AEM cai. Thanks for any insight.
the plenum of your IM and your TB are different sizes. You need to bore out your TB to 64.. or taper it to 64mm... the whistling is from the air going over the ridge caused from the size difference.
Thanks for that!!! Wish I would have thought of that.
Now I miss my low end power...... oh and by the way, my idle is about 1k and I have adjusted the idle screw as far in as it will go, any suggestions on this too?
You know.... I just noticed this, when I turn off the key, the famous K&N sucking noise is no longer there. Is that normal too?
No b/c my friend has the Skunk2 IM and his still does the air noise when you shut off the car.
Install went very smoothly. The hardest part to me was cutting in to the wire harness loom and rerunning the wires for the a/t sensor and the IACV sensor, and that really wasn't too bad either. Jumbos, what throttle body is your friend using and what intake. Thank you to everyone so far.
Just FYI.... I took the JDM R t/b off and noticed that the USDM gasket doe not completely seal the t/b on the bottom side. I switched over to my GSR gasket and has cured some of the whistling.
Okay, tonight I swapped the GSR t/b out and NO whistling.... so what that means is that on the JDM itr t/b a vacuum port on the bottom is not being plugged or vented to to inside of the t/b port in the manifold. I plugged it and have no whistling with the ITR t/b anymore but I would like to buy a JDM ITR t/b gasket to fix it right. Anybody know where I can get one......... and I don't want to use Hondabond on it either.
germanEE8
Feb 25, 2004 08:56 AM
