ODOMETER Question....
Old Jun 12, 2003 | 05:24 PM
94GeeZR's Avatar
Default ODOMETER Question....
everything in the gauge cluster (95 gsr) workes except for the odometer and tripometer. I toke it apart and it looks like one of the plugs is missin...anyone have a picture of all the plugs and which ones are neccesary for the odometer to work...i think theres 3 plugged in and one left...its pretty long...anyone?
Old Jun 12, 2003 | 06:03 PM
94GeeZR's Avatar
Default Re: ODOMETER Question.... (94GeeZR)
BUMPPPPPP HELPPPP Pleaseeeeeeeeeeeeeeeeeeee
Old Jun 12, 2003 | 06:07 PM
Havokmkr's Avatar
Bump for someone hoplessly in need.
Old Jun 12, 2003 | 06:13 PM
mr.beeks's Avatar
sorry for not catching it earlier...
Ok did you take out the dash and there are about 4 plugs there right
but they have nothing to do with odometer or trip meter
well you will see a cable with no plug sticking right out but you cant
move from position.
this cable is the one you need to plug into the gage cluster but you might
be missing the clip that goes on the cable and attaches to cluster
maybe thats what you are missing??
let me know if what I described is correct..
Old Jun 12, 2003 | 07:03 PM
94GeeZR's Avatar
Default Re: ODOMETER Question.... (N T R Z R)
ummm....that got me even more confused...can u try to explain it in stupider form...lolz
Old Jun 12, 2003 | 07:08 PM
mr.beeks's Avatar
you are missing the plug for that wire that goes into the
gage cluster...
Old Jun 12, 2003 | 07:10 PM
94GeeZR's Avatar
hmmm...well....the alarm is ghetto rigged...i was wonderin if that would have anything to do with it? would he have taken that plug and used it fo sumtin else? if not...i dunno where that plug is...im still lost...sorry im so stupid....
Old Jun 12, 2003 | 07:57 PM
AnNiMosSiTY's Avatar
is ur gauge cluster ur usin from another year car?
Old Jun 12, 2003 | 08:07 PM
94GeeZR's Avatar
Default Re: ODOMETER Question.... (AnNiMosSiTY)
acually yea it is...itz a 95 gsr wit a 99 guage cluster....i completely forgot to ask if that mattered...d=X....lolz does it?
Old Jun 12, 2003 | 08:21 PM
gSr_jB's Avatar
Hmm maybe its not a plug. Check ur alt spd sensor fuse...its a 7.5A fuse that coulda gone. If not that you can check ur VSS sensor as well as it may have gotten wet due to rain or just gone bad. Did it just randomly happen or when u put in the 99 cluster?
Old Jun 12, 2003 | 08:29 PM
94GeeZR's Avatar
Default Re: ODOMETER Question.... (gSr_jB)
honestly...i bought the car like that...i kno imma dumbass....but i kno it was from the sellers other 99'. i already checked the fuses and they all seem to be fine....so how would i go about checkin the vss sensor?
Old Jun 12, 2003 | 10:03 PM
akhom's Avatar
Well your problem is 98-01 integra clusters will not wire up to 94-97 integra.
It all plugs in but the wires are wrong and it will not play correctly.
Good luck
eg515
Feb 24, 2013 02:58 AM
blac00si
Nov 10, 2005 12:33 PM
d16X
Dec 21, 2004 10:48 AM
cutt
Nov 12, 2004 06:57 PM
EGRhatch
Jan 17, 2004 05:24 PM
