Fuel relay problems DB2
Old Jun 13, 2003 | 10:28 AM
nafreak's Avatar
Default Fuel relay problems DB2
This is a known problem for our cars and I thought that I had fixed it by going in and resolding the connections. It still seems to give me problems the past couple of days.
Q1. IS there anyway to test the relay?
Q2. Is the anything else that might be cause the I could check first before dropping ~$60 on the relay?
TIA!
Old Jun 13, 2003 | 03:39 PM
nafreak's Avatar
Default Re: Fuel relay problems DB2 (nafreak)
bump
Old Jun 13, 2003 | 03:58 PM
VintegraGSR96
Guest
Posts: n/a
like big ****?
Old Jun 13, 2003 | 04:52 PM
nafreak's Avatar
Default Re: Fuel relay problems DB2 (VintegraGSR96)
Thanks......
Anyone else with helpful information?
Old Jun 14, 2003 | 07:35 AM
startroops's Avatar
just go to a junkyard and pick up another relay... it's not going to cost you anymore than 20US. RZ-0063 or RZ-0067, either one will work.
Old Jun 14, 2003 | 07:39 AM
g2 GS-Argh's Avatar
The unfortunate part of trying to test a relay is that sometimes the relay works, and sometimes it doesn't. When your car won't start (usually when it's hot outside), just listen for the fuel pump to turn on under the rear seat. If you don't hear it turn on, then the relay is to blame.
As for your second question, we need to know what your car is doing in order to tell you what else it may be.
Old Jun 15, 2003 | 12:37 PM
nafreak's Avatar
Default Re: Fuel relay problems DB2 (g2 GS-Argh)
Thanks for the replys guys! Startroops! Fellow G2ICer!
Yeah I was pretty sure it is the relay, but I wanted to see if there were other posiblities. Since I didnt see any visable cracks in the solder like the teg tips said.
Ill give the salvage yard or acuraautomotiveparts.net a ring. Thanks!
Xampuls
Oct 12, 2015 02:45 PM
ckirso
Mar 18, 2013 08:08 AM
LS_teggy
Aug 5, 2010 08:41 PM
Kidnkorner
Apr 4, 2010 08:54 PM
RuskeR
Nov 15, 2006 08:30 AM
