Shifter thread
Old Jun 12, 2003 | 04:42 AM
VTechie's Avatar
Default Shifter thread
Does anybody happen to know the thread spec for the shifter (for threading on the ****)? I need the pitch and diameter.
Old Jun 12, 2003 | 04:43 AM
2k1_ITR_0736's Avatar
Default Re: Shifter thread (VTechie)
i think its about the same as the wheel studs.
try 12x1.5
Old Jun 12, 2003 | 06:44 AM
skygtr01's Avatar
Default Re: Shifter thread (2k1_ITR_0736)
I am not sure of the actual diameter, but I do know it's larger on my 94 LS then my 00 GSR. I don't know if the diameter was always different between the LS and GSR or if they changed it in all models from 98 on.
Old Jun 12, 2003 | 07:04 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Shifter thread (skygtr01)
That's odd, all Hondas I've seen so far have been 8mm diameter (not sure of the pitch). I know my 94 GS-R, my friend's 2002 EP3 Si, and my other friend's 2002 S2000, and my other friend's 95 Civic coupe all have the same thread because we can all interchange shift *****.
The thread is 8mm for sure, but I'm not sure of the pitch.
Old Jun 12, 2003 | 08:19 AM
Default Re: Shifter thread (PatrickGSR94)
hmm, mine is bigger than that.... 8mm is the same size as what hold your shift linkage up, but im positive mine is bigger than that.
Old Jun 12, 2003 | 08:58 AM
Community Builder
Okay folks, it's 10x1.5mm. I just checked it with a die on my shifter, and that's what it is. ALL Civics, Integras, S2000's, and RSX's use that same thread size on all their shift *****.
Old Jun 12, 2003 | 09:08 AM
VTechie's Avatar
Just went outside with an M10x1.5 tap, which matches the threads exactly. Since I don't think they make an M8 larger than 1.25, I think this is it.
Old Jun 12, 2003 | 09:53 AM
Community Builder
yeah, my M8 die would not fit over my shifter, obviosuly because the 10x1.5 one did.
I coulda sworn it was 8mm just from memory, but I was proven wrong.
pumafeet10
Jan 15, 2021 04:17 AM
DC206R
Jan 10, 2009 08:47 AM
JDean6pac
May 17, 2007 04:24 PM
sickofitall1113
Apr 19, 2007 08:03 AM
Pineapple Devil
Feb 8, 2002 05:36 AM
