Engine Shock Absorber - DC2
Old Jun 11, 2003 | 07:41 PM
integra-modder's Avatar
Default Engine Shock Absorber - DC2
J's Racing Integra Engine Shock Absorber DC2
I was looking at this item because I have noticed that a few people have these. Anyone has more input about them?
http://www.jsracing.co.jp/index2.html
Old Jun 13, 2003 | 10:01 AM
Default Re: Engine Shock Absorber - DC2 (integra-modder)
TTT
Old Jun 13, 2003 | 10:04 AM
PoW3l2BaN's Avatar
Im guessing you can get the same effect with Energy Suspension motor mount inserts. but dont take my word for it.
Old Jun 13, 2003 | 10:12 AM
Tweakmeister's Avatar
get engine mounts instead.
Old Jun 13, 2003 | 10:24 AM
ebelp's Avatar
Default Re: Engine Shock Absorber - DC2 (PoW3l2BaN)
I found a pic! Took me forever to find it....this pic was posted by user olskodumie
That thing is sweet looking!
Old Jun 13, 2003 | 10:53 AM
Padawan's Avatar
Darth ModerVader
I believe some modification is necessary when using the damper on LHD Integras.
Old Jun 13, 2003 | 02:06 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Engine Shock Absorber - DC2 (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">I believe some modification is necessary when using the damper on LHD Integras.</TD></TR></TABLE>
Why is that, there shouldn't be any difference in the places that thing bolts to (engine and shock tower) whether the car is LHD or RHD.
Old Jun 13, 2003 | 03:21 PM
Default Re: Engine Shock Absorber - DC2 (PatrickGSR94)
in a previous thread about this that was talked about.
Old Jun 13, 2003 | 04:12 PM
sloppy_seconds's Avatar
Banned
Default Re: Engine Shock Absorber - DC2 (Tweakmeister)
yeah search for katman's thread on here....he did it in his car some time ago. from there, you should be able to find another thread on why the brcket was modified to make it fit an LHD car. think it was something with the master cylinder or something.
Old Jun 13, 2003 | 04:22 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Why is that, there shouldn't be any difference in the places that thing bolts to (engine and shock tower) whether the car is LHD or RHD.</TD></TR></TABLE>
The picture that was posted is of the Civic version of the damper. On the Integra, you can clearly see that the MC would interfere with the damper on a LHD vehicle.
Old Jun 13, 2003 | 04:42 PM
ingrate's Avatar
25 Year Member
Someone in the ITR forum cut out a portion of that bracket you see there on the right so it doesn't contact the brake MC. FYI there's no damper available for the passenger side.
Old Jun 13, 2003 | 05:23 PM
94TealGSR's Avatar
Here's a better solution...
LHT Performance makes the engine damper and master cylinder brace in one...
Check it out here!
Old Jun 13, 2003 | 11:18 PM
Default Re: Engine Shock Absorber - DC2 (ebelp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp &raquo;</TD></TR><TR><TD CLASS="quote">I found a pic! Took me forever to find it....this pic was posted by user olskodumie
That thing is sweet looking!</TD></TR></TABLE>
Yea, I saw that pic and asked olskodumie, he said his dash shook like hell and he has mass wheel hop. Getting this thing solved it.
Here's the link to jsracing: http://www.jsracing.co.jp/index2.html
Old Jun 14, 2003 | 06:18 PM
MugenGTR's Avatar
i think it's a waste of money, the motor mount inserts are like $35
Old Jun 14, 2003 | 08:02 PM
Westrock2000's Avatar
Default Re: Engine Shock Absorber - DC2 (MugenGTR)
Could you effectively do the same thing by mounting a more traditional shock between the motor and the engine bay? I always wondered if car manufactures ever used this technique, that way you would get a progressive control of engine movement, and you wouldn't have to use overly hard materials like the ES inserts that cause vibrations at all engine loads. Maybe like a shock on both sides of the motor, connected to the firewall or strut tower?
Its hard to tell, but is the J's thing just like an adjustable bolt, or is it an actual shock?
Old Jun 18, 2003 | 09:47 PM
Default Re: Engine Shock Absorber - DC2 (Westrock2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Westrock2000 &raquo;</TD></TR><TR><TD CLASS="quote">Could you effectively do the same thing by mounting a more traditional shock between the motor and the engine bay? I always wondered if car manufactures ever used this technique, that way you would get a progressive control of engine movement, and you wouldn't have to use overly hard materials like the ES inserts that cause vibrations at all engine loads. Maybe like a shock on both sides of the motor, connected to the firewall or strut tower?
The J's unit is an actual damper. Its designed like a shock just doesnt have liquid inside, It uses rubber which compresses and expands to stabalize the two jointed objects.
Old Jun 18, 2003 | 09:49 PM
Aaron M's Avatar
looks like a mini tein
Old Jun 19, 2003 | 02:10 AM
IntEGNYC's Avatar
the Mini Me of shocks :D
Old Jun 19, 2003 | 10:05 AM
roadrunner's Avatar
Default Re: Engine Shock Absorber - DC2 (IntEGNYC)
my '89 944 turbo has liquid filled engine mounts that filter out an unbelievable amount of vibration. When they went out, the interior mirror fell off the windshield after only 3 days while I was waiting for the replacements...
Old Jun 19, 2003 | 12:22 PM
ragejed's Avatar
Default Re: Engine Shock Absorber - DC2 (roadrunner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roadrunner &raquo;</TD></TR><TR><TD CLASS="quote">my '89 944 turbo has liquid filled engine mounts that filter out an unbelievable amount of vibration. When they went out, the interior mirror fell off the windshield after only 3 days while I was waiting for the replacements...</TD></TR></TABLE>
There is a difference in vibrating because the motor is loose, and from the motor being held in well.
Old Jun 19, 2003 | 01:02 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Westrock2000 &raquo;</TD></TR><TR><TD CLASS="quote">Could you effectively do the same thing by mounting a more traditional shock between the motor and the engine bay? I always wondered if car manufactures ever used this technique, that way you would get a progressive control of engine movement, and you wouldn't have to use overly hard materials like the ES inserts that cause vibrations at all engine loads. </TD></TR></TABLE>
Lexus does this
Old Jun 19, 2003 | 05:19 PM
Default Re: Engine Shock Absorber - DC2 (.RJ)
I wonder if I could find something cheaper...something maybe under 100 for this purpose.....
Old Jun 19, 2003 | 05:24 PM
2lowintegra's Avatar
what is the point?
p4vlik.cz
Aug 7, 2006 04:43 AM
-Championship-
Jul 27, 2006 02:48 PM
GUILOTINE
Dec 5, 2005 10:51 PM
ITR01845
Jan 21, 2005 06:09 PM
Timmy!
Jun 30, 2004 03:24 PM
