Freon Problem
Old Jun 13, 2003 | 05:24 AM
BlackB18CTeg's Avatar
Default Freon Problem
Well, my A/C wasnt working, so I go pick up a freon bottle at Advance for the R-134A system. ANyway I pressure checked the system and its in the red, about halfway in the red. I am pretty sure this is the problem. Anyone have ANY Idea how to releave the pressure?
Old Jun 13, 2003 | 08:05 AM
JimBlake's Avatar
Default Re: Freon Problem (BlackB18CTeg)
If high side is too high while its running, maybe your expansion valve is plugged. Sometimes the receiver/dryer spills its guts into the lines & that plugs up the valve. Gotta evacuate it, open it, & figure out which component is plugged.
If you jumper the safety switches so it still runs, you might destroy your compressor too. So it's a good thing you didn't just ignore the pressure & add the refrigerant anyway.
Old Jun 13, 2003 | 09:03 AM
tilt's Avatar
If you want to do it the cheap method just stick a car key or anything with a tip onto the low-side adapter and let it out. Do it outside with some wind to avoid inhaling the fumes, you can die from too much of it.
Old Jun 13, 2003 | 09:19 AM
romeo619romeo's Avatar
Default Re: Freon Problem (tilt)
if it shuts off.. its becuz of the high side.. release some pressure from the high side and you should be set
Sinner
Aug 9, 2022 06:27 PM
greenquark
Jul 15, 2016 03:54 PM
kct01
Acura TL, RL & ZDX
Jun 6, 2013 06:45 PM
john85020
Honda CR-V & Element
Jun 27, 2012 09:09 PM
soon2bdropped
Aug 3, 2010 09:38 PM
