stroke 'n bore!!
Old Jun 14, 2003 | 10:33 PM
SRL's Avatar
SRL
Default stroke 'n bore!!
can some1 please explain to be about stroked and bored out an engine? I kno stroke is for increasing displacement, and bore is enlarging the block piston wall (is it?). Let say i have a b16a2, and wanting to increase the displacement to 1.8, what do i have to do? also, does gsr crank fit in b16 block? btw, sorry for the noob questions
Old Jun 14, 2003 | 10:35 PM
P1mpSlap's Avatar
buy a GSR block.
You'll **** up the rod/stroke ratio if you do that kind of ghetto rigging by mixing up the cranks like that.
I doubt you will want to spend 2300 bux on a Toda stroker kit either, and you still wont be able to rev it high.
Old Jun 14, 2003 | 10:46 PM
SRL's Avatar
SRL
Default Re: (P1mpSlap)
hehe, it was just a thought, but u turned it down thanx tho. One more ?, does obd1 and obd2 blocks different? i think the head is the b*tch that determine the ecu type right? let say i have a obd1 b16a1 head, can i somehow convert it into obd2 by swappin the distributor or something?
Old Jun 14, 2003 | 11:15 PM
romeo619romeo's Avatar
Default Re: (1KleanTeg)
a type R is actually what toda uses in there b16 stroker kits last i checked
Old Jun 15, 2003 | 03:55 AM
Westrock2000's Avatar
Default Re: (romeo619romeo)
Get your block resleeved and bore it 84mm-86mm, that will give you 1.8L and not screw up any geometry.
A bigger crank ( ) doesn't increase displacement anywhere what a bigger bore does.
Old Jun 15, 2003 | 08:00 AM
Tweakmeister's Avatar
Default Re: (Westrock2000)
if you're going to bore at all might as well go 2.0l
or just get a b18c block and go from there
Old Jun 15, 2003 | 08:10 AM
seanb18c1's Avatar
Boring->increases displacement.
Stoking-> increases displacement and puts more stress on your sleeves/piston rings and lowers your redline.
This will allow you to play with sizing:
http://www.c-speedracing.com/h...c.php
teg-9
Feb 22, 2010 12:11 PM
hondachris1994
21
Jan 9, 2007 11:34 PM
second edition
Jul 15, 2005 04:54 PM
toda_eg6
Mar 6, 2005 07:53 AM
hmongdude
May 7, 2003 04:02 PM
