e Teg ECUs
Old Jun 14, 2003 | 09:37 PM
redEF's Avatar
Default Teg ECUs
is the 87 ECU the same as the 89?
Modified by redEF at 7:09 AM 6/15/2003
Old Jun 14, 2003 | 10:11 PM
redEF's Avatar
bump, cuz i need to know before i buy this ECU
Old Jun 14, 2003 | 10:55 PM
thaiphob's Avatar
Nikon!!!
Default Re: (redEF)
which ecu are you buying??? the PG7??PM7?? what motor r u going to use the ecu with? dohc zc??? a lil more detail will get you better answers.
Old Jun 14, 2003 | 11:01 PM
redEF's Avatar
i dunno, its for my cousin, he has an 87 teg motor in his 87 Civic Si. his ecu burned up and i was trying to find out if he could use an 89 ecu to replace it
Old Jun 14, 2003 | 11:03 PM
thaiphob's Avatar
Nikon!!!
Default Re: (redEF)
if he has either it should be fine.
Old Jun 14, 2003 | 11:05 PM
redEF's Avatar
well someone told him the plugs are different
i think that that someone is full of ****, but i wanted to make sure
Old Jun 14, 2003 | 11:15 PM
redEF's Avatar
so he is full of **** right?
Old Jun 15, 2003 | 02:34 AM
thaiphob's Avatar
Nikon!!!
Default Re: (redEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redEF &raquo;</TD></TR><TR><TD CLASS="quote">so he is full of **** right?</TD></TR></TABLE>
pretty much.
Old Jun 15, 2003 | 10:24 AM
redEF's Avatar
bump for more info, he has an '87 LS 1.6 engine, so will the 89 LS or RS ( i dunno if there is a diff) work with it
Old Jun 15, 2003 | 08:39 PM
thaiphob's Avatar
Nikon!!!
Default Re: (redEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redEF &raquo;</TD></TR><TR><TD CLASS="quote">bump for more info, he has an '87 LS 1.6 engine, so will the 89 LS or RS ( i dunno if there is a diff) work with it</TD></TR></TABLE>
the Rs n Ls motors are the same.
driftam1
Oct 27, 2008 02:43 PM
pirocrxracer
Oct 26, 2003 04:04 PM
86CRXSi
Jun 17, 2002 02:01 AM
USDM 4G VTEC
May 13, 2002 06:00 AM
USDM 4G VTEC
May 13, 2002 05:59 AM
