Window bounce while openning windows
Old Jun 12, 2003 | 07:23 AM
integra-modder's Avatar
Default Window bounce while openning windows
http://www.team-integra.net/se...D=552
Ive looked at that, and what to know if anyone knows whether its caused by the same problem. Im assuming its a lack of lube on some of the moving parts of the window after they get wet.
This only happens when it rais. The window falls 1/4 inch, then stops (while the motor still pulls it down), then falls 1/4 and stops. This continues the whole way down.
If you know anything, let me know.
Thanks,
D
Old Jun 12, 2003 | 07:42 AM
tilt's Avatar
Default Re: Window bounce while openning windows (integra-modder)
Might want to try lubing up the window track. Use the oil for air tools, it doesnt collect dirt like grease.
Old Jun 13, 2003 | 09:41 AM
Default Re: Window bounce while openning windows (tilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">Might want to try lubing up the window track. Use the oil for air tools, it doesnt collect dirt like grease.</TD></TR></TABLE>
Thanks, can you get this stuff at home depot and so on?
Anyone know whats the white sealant used to hold on the plastic sheet to the door behind the door panel?
Old Jun 13, 2003 | 10:18 AM
tilt's Avatar
probably. Ive seen the stuff at walmart too.
Old Jun 13, 2003 | 10:33 AM
B00STeD's Avatar
mine does the same thing when it rains, I wouldn't worry too much about it
98exowner
Oct 12, 2008 10:07 PM
MiracleWhip
Dec 20, 2007 04:49 PM
Sean @ ESG
14
Sep 9, 2005 09:21 PM
mugenspoongsr
May 30, 2005 07:23 PM
EX-T
Dec 2, 2003 03:53 PM
