Clutch problem
Old Oct 4, 2004 | 03:31 PM
Integra99's Avatar
Default Clutch problem
I just changed my master cylinder and i bleed the system out. I have no clutch pedal just a little bit of pressure to it, and I cant even get it into gear (if i push hard enough it will grind). Also the slave cylinder is only like a month or 2 old. Does anybody have any ideas on what might be wrong with it.
Old Oct 4, 2004 | 04:04 PM
slo2kgsr's Avatar
Default Re: Clutch problem (Integra99)
keep bleading the system also make sure you have no leaks. It takes a while to work all the air out.
Old Oct 4, 2004 | 04:16 PM
Integra99's Avatar
my buddy who was helping me bleed it out said that it was all the way bleed, so i have no idea.
Old Oct 4, 2004 | 04:17 PM
EV1L SI's Avatar
SCAM ARTIST
Default Re: (Integra99)
It takes a while to get all the air out like said above. Do it over and over and over until you have pedal pressure that you are use to, that should take care of your issue.
Dool_Ohver_Hed_Cam
Jul 3, 2007 06:01 PM
importfanatic17
Jan 1, 2007 10:00 PM
0bLiViOuS
Dec 2, 2006 07:36 AM
karmadhi
Oct 9, 2006 03:12 PM
Noahk
Oct 7, 2005 01:59 AM
