high idle
Old Oct 4, 2004 | 01:40 PM
Mr. JDM-GSR's Avatar
Default high idle
i had a rip in my intake manifold gasket and i changed that out and cleaned my throttle body. i then found that i need a new pcv valve but then there is still a vac leak.
this is on a jdm gsr; i cant figure what else would have my idle at 1500 when warmed up
any suggestions?
Old Oct 4, 2004 | 03:56 PM
boosted k20's Avatar
Default Re: high idle (Mr. JDM-GSR)
Try lowering ur idle speed. On the top of the throttle body there's a flat head screw. turn that screw clockwise to lower ur idle speed.
u might need to take a flat head screw driver and hit it with a hammer on that screw in order to turn it. the head on the screw is not deep enough to turn, so u might need to mave the groove bigger with the screw driver and hammer.
u live in Jamiaca queens? i live in Richmond Hill
Old Oct 4, 2004 | 06:16 PM
Default Re: high idle (boosted k20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">Try lowering ur idle speed. On the top of the throttle body there's a flat head screw. turn that screw clockwise to lower ur idle speed.
u live in Jamiaca queens? i live in Richmond Hill</TD></TR></TABLE>
ive screw that damn thing all the way down and it cant go no more
and i dont want to replace each and every vac hose
i havent been by richmond hill in a while
RDAYA0
16
May 1, 2008 10:25 PM
SloCrxDx91
Sep 20, 2005 11:14 PM
Steezn4NOReason
Dec 4, 2004 09:02 PM
aengnr1
May 28, 2003 01:39 PM
fe519
Nov 21, 2002 05:58 PM
