Help with IACV maybe?
Old Oct 5, 2004 | 06:07 PM
handa's Avatar
Default Help with IACV maybe?
My friend has a stock auto 94 Integra LS and it's throwing code 14 (IACV).
Here's what's happening, when it's parked or on neutral, the idle revs back and forth 1200-2000rpm constantly. Put it onto D and it jerks the car THUMP!!!
I unplugged the IACV and the idle revving stops. Put it onto D and it jerks the car THUMP also!
I've tested the IACV plug wire and it's reading 12.4V...which is perfect. I'm not sure if the IACV is bad or not, any way to test it? Any ideas as to what could be wrong?
Thanks!
Old Oct 6, 2004 | 07:49 AM
JimBlake's Avatar
Default Re: Help with IACV maybe? (handa)
When you unplug the IACV, what rpm does it go to? It's supposed to be low, around 450 or so on my '95. Maybe you need to adjust the base idle? Probably wouldn't hurt to clean out the IACV either.
Old Oct 6, 2004 | 12:55 PM
handa's Avatar
Default Re: Help with IACV maybe? (JimBlake)
When I unplugged the IACV, the RPM dropped down slightly around 500 constant.
I'll try adjusting the idle. Thanks for the reply.
JSR
May 17, 2006 10:27 PM
turbotime
Oct 24, 2005 12:01 PM
4ghatch
Sep 28, 2005 02:59 AM
xd69
Jun 4, 2005 09:31 AM
B16CRXT
Aug 31, 2004 06:13 PM
