Piston Scratch (useable)?
Old Oct 6, 2004 | 05:15 PM
ferio 95's Avatar
Default Piston Scratch (useable)?
A freind of mine wants to sell me some usdm itr pistons that are slightly used but i noticed they have lil scratches around the dome are circled in this example pic
<U>*this is not the real piston*</U>
Is it useable with these scratches? or will they have sealing problems
Modified by ferio 95 at 8:29 PM 10/6/2004
Old Oct 6, 2004 | 05:26 PM
stareatsun's Avatar
that part of the piston does not touch the cylender wall, the rings doo.
Old Oct 6, 2004 | 05:28 PM
ferio 95's Avatar
Default Re: (stareatsun)
so it doesnt matter? its on top as well as the side of the circle area
Old Oct 6, 2004 | 06:26 PM
SwiftTone's Avatar
Default Re: (ferio 95)
yes its useable. Even pistons with dents on top from valve to piston contract are usable. Maybe lower ur compression slightly(VERY slightly) but it should be fine to use. Lets just say I would use it if I were you
Old Oct 6, 2004 | 06:37 PM
ferio 95's Avatar
Default Re: (SwiftTone)
ok cool thanks
Old Oct 6, 2004 | 06:42 PM
mr.beeks's Avatar
best advise is not to be cheap and use "used pistons"
they already shaped like the old cylinder wall that they were in so
right now it will not smoke but down the road it will so best bet
is to buy new ones....
this is talking from experience...
Old Oct 6, 2004 | 07:06 PM
SwiftTone's Avatar
Default Re: (mr.beeks)
Yes, I forgot to address that issue. That pistons will be shaped like the cylinder of the block that it came out of. So I kinda half answered the question.
Old Oct 6, 2004 | 07:11 PM
ferio 95's Avatar
I se well that makes a huge difference in the value of these pistons
Old Oct 6, 2004 | 07:15 PM
SwiftTone's Avatar
its only a possiblity and theory. Dunno if it really happens in real life. It makes sense though. If we did everything by the book at work, we'd make no money.
Old Oct 6, 2004 | 07:16 PM
mr.beeks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferio 95 &raquo;</TD></TR><TR><TD CLASS="quote">I se well that makes a huge difference in the value of these pistons</TD></TR></TABLE>
yeap the value of recycling the metal not the usage
but if you wan to continue with it go ahead
let me be the first one to say:
"I told you so"
Old Oct 6, 2004 | 09:55 PM
ferio 95's Avatar
lol well for the money i could spend on these i can buy some new set of si pistons which will yeild the same compression in my setup as some jdm p73's
JJDub
Engine Machining & Assembly
May 31, 2017 07:30 AM
95dc2teg
Dec 21, 2009 07:08 PM
zenon8890
Feb 5, 2009 06:01 PM
5_Lug_B
Aug 5, 2007 09:26 PM
scrubachu
Nov 20, 2003 12:07 PM
