Idle problem
Old Oct 6, 2004 | 05:28 PM
galioth's Avatar
Default Idle problem
my integra idles reallly high when i start it up and then goes back down... then goes back up then goes back down, it does this for about 5 minutes until the engine warms up... it revs to about 3k and back down to about 1k.. does any one know what this problem is or have had this problem before....
i have heard it could be the idle air control valve... but i have taken that off and cleaned it thoroughly(spelling?) i also heard it could be vacume lines but i figured it would never go away if it was vacume lines.. so if anyone has had this problem before and know how to fix it please help me......thanks
Old Oct 6, 2004 | 06:20 PM
galioth's Avatar
Default Re: Idle problem (galioth)
Help!
Old Oct 6, 2004 | 06:23 PM
SwiftTone's Avatar
if you think it maybe the vauum lines? check the vacuum! . At idle, it should be at 40-50psi vacuum. At WOT it shoudl go down to 0
Old Oct 6, 2004 | 06:34 PM
galioth's Avatar
Default Re: Idle problem (SwiftTone)
but i don;t think its the vacume lines.... wouldn;t it always do this if it was vacume lines.. it goes away when it warms up...
Old Oct 6, 2004 | 06:36 PM
hadehatch's Avatar
check if you have enough coolant in the system or if there is any air in the cooling system
Old Oct 6, 2004 | 07:08 PM
SwiftTone's Avatar
I would still advise you to check it. Sometimes it could be more than one thing that would cause it. We should just try to eliminate the possibilities. Also, the idle control valve could be an issue.
Old Oct 6, 2004 | 08:19 PM
blah116's Avatar
i just brought my integra to the mechanic for this problem. hes ordering the part but i forgot what it was called. i'll let you know when it comes in. and he said this is not a major problem and its not something you must fix.
Old Oct 7, 2004 | 03:29 AM
galioth's Avatar
Default Re: Idle problem (blah116)
yeh i don't have to fix it.. but its really anoying.. could it be the tps sensor?
Old Oct 7, 2004 | 12:20 PM
galioth's Avatar
i read something about taking my intake off and covering the holes in the throttle body... and it ran perfect.. no idle prob.. but when i took my fingers off the holes it went back to idleing high... this is the tps sensor right? can i just buy a new tps sensor or do i need to buy a whole new throttle body... and i read about bypassing the tps sensor with jb weld... anyone know if that will work.
Old Oct 7, 2004 | 02:20 PM
blah116's Avatar
the part my mechanic ordered was the fast idle valve
Old Oct 28, 2004 | 03:47 PM
Smooth-GSR's Avatar
What year is your car? obd1 or obd2? I'm having the same issues, but I don't think my obd2 b18b has a fast idle sensor....
djviet2000
Aug 20, 2008 08:19 PM
1kleenef
Sep 29, 2007 07:39 AM
sikluder
Jun 29, 2006 05:44 PM
BOOSTED_JDM_DB8
Feb 3, 2006 01:01 AM
redpeppers
Jul 26, 2005 05:10 AM
