weird idling and sputtering
Old Oct 3, 2004 | 06:57 PM
hdeuce's Avatar
Default weird idling and sputtering
h22 in 94 LS...under normal driving conditions car will run right then it will start to cough, sputter, and lose power. seems to do it whenever i hit larger bumps in the road or under cornering. whenever it does this, the a/f guage wont even read. sometimes it will even shut off when in neutral or just sitting at red lights. acts like the fuel is just cutting off. also when v-tec is engaged a/f goes very lean even with the fuel bumped up on the afc. ne one??
Old Oct 3, 2004 | 06:59 PM
mr.beeks's Avatar
Default Re: weird idling and sputtering (hdeuce)
its sounds like a faulty Oxygen sensor...
Old Oct 4, 2004 | 12:06 AM
yeegsr's Avatar
Default Re: weird idling and sputtering (mr.beeks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks &raquo;</TD></TR><TR><TD CLASS="quote">its sounds like a faulty Oxygen sensor...</TD></TR></TABLE>
hmm,,,could be O2 problem....but my ilding problem ccome from tranny lacking oil
i was tranny oil change...and jack up my car drain oil out, and refilled it while it still on the jack...so the oil level was equally. So, a day later..my idling start crying..drops to about dying and go back up....at red light almost died so many...so i decided to drain oil again...and lower the car to normal level..and refill and the idling work fine now....
for you if you hit some..check ur starter...there is a wire that connects from battery POSITIVE TO STARTer, so it might get lose after u hitted the rock or pump...and...gigling around cuzing idle to struggle...where a glove when youre trying to fix it...
RESET ECU....
MatthewMenze
Nov 6, 2013 04:04 PM
FlyingDaggers
Dec 19, 2007 02:04 PM
evolvedAP1
Jun 29, 2006 01:15 PM
5genprelude
Mar 15, 2006 04:58 PM
xxredpreludesixx
Jun 8, 2005 09:50 PM
