MSD Distributor Cap Question
Old Oct 6, 2004 | 10:49 AM
Beezle's Avatar
Default MSD Distributor Cap Question
We'll I bought a new distributor cap yesterday and went to go put it on. The stock one has a little indentation on the top where this little plastic rod with a spring goes through. Well on the MSD cap where that rod goes there is that red plastic peice in the way. Can anyone help me please?
Old Oct 6, 2004 | 10:56 AM
PlastikOwl
Guest
Posts: n/a
Default Re: MSD Distributor Cap Question (Beezle)
OMFG...
you realize that the MSD cap is for an external coil right?
The plastic piece is there, because your coil isn't even supposed to be in there anymore if you're purchasing that cap.
Old Oct 6, 2004 | 11:00 AM
Marauder's Avatar
Default Re: MSD Distributor Cap Question (PlastikOwl)
Yeah, the MSD cap is to convert to a external coil.
Here's a pic of my civic, you can see the MSD blaster coil on the passenger fender well and connected to the cap.
Old Oct 6, 2004 | 11:02 AM
PlastikOwl
Guest
Posts: n/a
Default Re: MSD Distributor Cap Question (Marauder)
Here are some pictures of my own setup.
You can see where the wire goes.
Old Oct 6, 2004 | 11:13 AM
Beezle's Avatar
We'll what would I need to do then? I know I could bring it back but how to I set it up to be external? Is there even a advantage in doing that? Btw, it's on a 97 Integra.
PlasikOwl your pics don't work.
Old Oct 6, 2004 | 11:16 AM
rastropovitch
Guest
Posts: n/a
Bwahahahahahahahahahahahahaha!!!!!
Old Oct 6, 2004 | 11:19 AM
Beezle's Avatar
Default Re: MSD Distributor Cap Question (MSchu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu &raquo;</TD></TR><TR><TD CLASS="quote">Bwahahahahahahahahahahahahaha!!!!!</TD></TR></TABLE>
Yea, I don't know anything about cars. I wan't to learn but no one really to show me.
Old Oct 6, 2004 | 11:21 AM
rastropovitch
Guest
Posts: n/a
Alright, let me read your post again and I will answer you
Old Oct 6, 2004 | 11:24 AM
rastropovitch
Guest
Posts: n/a
Okay, your not going to want to run an external coil... you can, but there is very little advantage with a stock engine set up. To run this CD ingnition, you would need to buy the external coil and an external ingnition(ie hi6 by crane etc) the cap and wire set... it is best that you return this cap and go and buy an OEM cap and call it a day. might as well get a rotor while your at it and your almost half way to a tune up
Old Oct 6, 2004 | 11:31 AM
Beezle's Avatar
Thanks man.
Old Oct 6, 2004 | 12:53 PM
importdude2000's Avatar
heres my setup
using a 92-96 prelude vtec external coil cap
Old Oct 6, 2004 | 03:44 PM
PlastikOwl
Guest
Posts: n/a
Default Re: (importdude2000)
I'm rocking the nology external coil/ignition module
plug & play..no wire splicing.
And it was free
Old Oct 6, 2004 | 04:07 PM
rastropovitch
Guest
Posts: n/a
Default Re: (PlastikOwl)
well if your runing a CD ingnition you would have to do a couple wires from inside the distributor
xlusiveracer
44
Apr 3, 2018 04:59 PM
SpoolnByYou
Mar 25, 2006 09:10 AM
J2turbo21
Aug 21, 2003 07:43 PM
J2turbo21
Aug 21, 2003 04:44 PM
CBR
Apr 10, 2002 08:44 AM
