Throwing an engine light....
Old Oct 6, 2004 | 10:21 PM
ZeroGSR's Avatar
Default Throwing an engine light....
I am throwing an engine light, but the only time it comes on is like 5 min into my drive. I have read about how to check your codes and everything, but unfortunatly when I turn my car off, my engine light turns off. So I don't know how to check it. Anyone got any ideas?
BTW 94 GSR
Old Oct 6, 2004 | 10:39 PM
(shockwave)'s Avatar
Default Re: Throwing an engine light.... (ZeroGSR)
you check your fluid levels?
Mine kept coming on because my coolant was running low. after i topped it off, the light still remained on.
i detatched the battery, plugged her back in and the light went away
Old Oct 7, 2004 | 04:57 AM
JimBlake's Avatar
There's a sticky thread at the top of this forum describing it...
It's normal for the light to go off when you turn off the car. But the ECU stores the code(s) in it's memory so you can retrieve it.
TeamSumner
Sep 29, 2014 05:14 AM
PIC Performance
Jun 12, 2006 10:37 PM
pens81
Acura TSX
Mar 30, 2006 03:42 AM
VTECVillain
Jan 6, 2002 11:40 AM
under_psi
Aug 16, 2001 12:50 PM
