obd1 to obd2?
Old Oct 7, 2004 | 08:54 AM
CountryStreetRacer's Avatar
Default obd1 to obd2?
hey guys i currently have a 94 ls and I am swapping a 99 GSR this weekend..only problem is i'm not sure what exactly needs to be done to go from obd1 to obd2..anybody know?
Old Oct 7, 2004 | 08:56 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: obd1 to obd2? (CountryStreetRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CountryStreetRacer &raquo;</TD></TR><TR><TD CLASS="quote">hey guys i currently have a 94 ls and I am swapping a 99 GSR this weekend..only problem is i'm not sure what exactly needs to be done to go from obd1 to obd2..anybody know? </TD></TR></TABLE>
If I recall correctly from when I helped a friend put a 96 GS-R engine into a 94 GS-R chassis.... all we had to do was swap the plugs on the injector harnesses, and use the 94 distributor on the 96 engine.
Of course you'll also have to add the necessary wires to your ECU harness and engine harness for VTEC and the dual stage intake manifold (assuming you use a P72 ECU). You could also run a Skunk2 manifold and a chipped P28 ECU and not worry about the wires associated w/ the dual stage manifold.
Nisif
Oct 20, 2012 06:11 PM
lilo_goki
11
Feb 15, 2008 12:07 PM
agy2k2
Jun 18, 2006 06:56 PM
thegsrfanatic
Aug 14, 2004 08:09 PM
hallsy
Feb 8, 2004 04:26 AM
