tranny problem
Old Aug 16, 2005 | 06:33 PM
ERIC!'s Avatar
Default tranny problem
i have a 94 LS and my tranny is acting up. my clutch makes noises when it is pushed in and when i release it. i have trouble getting into second and fourth gear and when i come to a complete stop, pretty much everytime all gears lock up and i cant get it in. i have to shut off the car and once i can finally get it into gear it is real smooth and the clutch is super soft. all this has been happening in the last two days. also my maintenance required light comes on. *goes out side to check how many times it blinks*
thanks for all the help
Old Aug 16, 2005 | 06:41 PM
Kendall's Avatar
Check to make sure the brake system is properly bled.
LSvtec03's Avatar
Default Re: tranny problem (elephantegra)
try bleeding the clutch fluid.
maint. req light doesn't mean anything. there's a button to turn it off under the steering column.
Old Aug 16, 2005 | 06:56 PM
ERIC!'s Avatar
Default Re: (Kendall)
can you explain what bleeding the brake fluid would do?
and i looked in my manual to see where the bolt is on the tranny to check the oil level but i cant tell where it is. i hate transmissions. anyone have a picture of where the bolt is?
Old Aug 16, 2005 | 06:57 PM
ERIC!'s Avatar
Default Re: tranny problem (LSvtec03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">try bleeding the clutch fluid.
maint. req light doesn't mean anything. there's a button to turn it off under the steering column.</TD></TR></TABLE>
im at 114k miles so im guessing the maint. req light just has to do with either oil change or my 115k mile service.
Old Aug 16, 2005 | 06:59 PM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elephantegra &raquo;</TD></TR><TR><TD CLASS="quote">im at 114k miles so im guessing the maint. req light just has to do with either oil change or my 115k mile service.</TD></TR></TABLE>
it has everything to do with nothing. it comes on at preset mileage intervals.
Old Aug 16, 2005 | 10:04 PM
Kendall's Avatar
Default Re: (elephantegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elephantegra &raquo;</TD></TR><TR><TD CLASS="quote">can you explain what bleeding the brake fluid would do?</TD></TR></TABLE>
Damn it, meant to type clutch system. My bad.
Old Aug 16, 2005 | 10:46 PM
the_23rd_letter's Avatar
the tranny drain bolt should be close to the bottom of the tranny and toward the rear of the car. a 1/2 box end of a wrench should fit in it. the fill plug is sorta central and toward the rear if i remember correctly. its reccomended to use Honda manual transmission fluid but you can get away with regular motor oil.
Edit: im an idiot its totally a 1/2 drive.
Modified by the_23rd_letter at 3:34 PM 8/19/2005
Old Aug 16, 2005 | 10:48 PM
by trouble do you mean it grinds really bad or just wont go in? sounds like either your synchros are shot or your pressure plate is fucked.
Old Aug 16, 2005 | 11:14 PM
Greddy Dantegra's Avatar
go bleed your clutch fluid.... it would clean out all that dirt and build up in the lines... after that... have a mechanic adjust your clutch by the pedals... your suppose to adjust your clutch every 15,000-20,000 miles or check underneath the driver side, by the pedals and look up see if you see any wet spots... if there is.... you might need a new CLUTCH MASTER CYLINDER! IF YOU STILL CANT GET INTO GEAR AFTER ALL THIS.... CHECK YOUR SHIFT LINKAGE SEE IF ITS BENT... OR YOU MIGHT NEED TO REBUILD OR GET A NEW TRANNY!
Old Aug 16, 2005 | 11:22 PM
ERIC!'s Avatar
Default Re: tranny problem (dvs gsr)
yikes. thanks guys. im getting it checked out tomorrow.
98_EL
Dec 12, 2006 11:23 PM
phoshizzle88
May 17, 2006 10:39 PM
Vi3tboy
Feb 1, 2004 02:33 PM
andrewasf77
Jun 19, 2003 07:32 PM
1fastdc2
Nov 4, 2002 02:09 AM
