how do you??
Old Aug 19, 2005 | 11:55 AM
sam95teg's Avatar
Default how do you??
how do you reset or make the maintance required light go away...help
Old Aug 19, 2005 | 11:57 AM
Spectrum24x's Avatar
Default Re: how do you?? (sam95teg)
Pretty sure you put your ignition key in a slot on the cluster...
i have a 91 so no maintnece light, but i think thats what my friend said.
Old Aug 19, 2005 | 11:58 AM
hotsuma23's Avatar
Put your hand on the right side of your steering column and follow it down the line under the visible part of it. Down there is a light blue square button that you just hold down for a few seconds until it turns off.
the_23rd_letter's Avatar
theres a button, i think its green, under the dash on the drivers side just to the right of the steering column. turn your accessories on and hold it down for three seconds then turn off the car and turn it back on and you should be good. At least i think thats how it goes if you have any problems let me know and ill go look at my teg
Old Aug 19, 2005 | 11:59 AM
Default Re: how do you?? (the_23rd_letter)
awww i totally thought i had this one
MSP's Avatar
MSP
there should be a button down on the bottom underneath your steering column
debogsr's Avatar
Default Re: how do you?? (Spectrum24x)
turn the ignition all the way to the right but do not start the engine.
Feel under the dash for a square button
press and hold that button until the check engine light goes off.
You have to press the button imediately after you turn the key for it to reset.
Old Aug 19, 2005 | 12:02 PM
.brian.'s Avatar
Default Re: how do you?? (debogsr)
if you are a visual learner........
http://www.team-integra.net/se...D=164
sam95teg's Avatar
thanx guys appreciate it..gonna go try it right now
Old Aug 19, 2005 | 01:33 PM
coronadrinker's Avatar
Default Re: (sam95teg)
Wasn't my post but thanks from me too
Old Aug 20, 2005 | 06:33 PM
Default Re: (coronadrinker)
I stand thouroughly corrected
bulig06
Aug 5, 2010 11:42 AM
94ls
Sep 22, 2008 08:03 PM
b20acura
Nov 24, 2005 09:44 PM
95lsinteg
Nov 17, 2003 12:05 PM
NeoGSR
Sep 11, 2002 07:22 AM
