BLEEDING ABS
Old Aug 17, 2005 | 04:05 PM
jonzel's Avatar
Default BLEEDING ABS
I was bleeding my hydrolic modulator and I accidentally let, the abs resivior run dry... Now the modulator buzzes, and after driving for about 20 minutes the abs light comes on. I'm not sure how to bleed the abs properly.... I tried starting the car and loosening the bleed screw, fluid drains and I replace it accordingly..... After repeating this process about 5 times I figured the abs system should be free of air, however the problem is still there... Am I bleeding the abs properly????
Old Aug 17, 2005 | 04:11 PM
jasonw's Avatar
1. What year? (so we know proper order)
2. How much fluid did you drain?
3. Are you using a pressure system at all?
Old Aug 17, 2005 | 05:45 PM
Keno20's Avatar
Default Re: BLEEDING ABS (jonzel)
you are bleeding all 4 arent you???
Old Aug 18, 2005 | 04:47 PM
jonzel's Avatar
Default Re: BLEEDING ABS (Keno20)
The reason i'm bleeding my abs is that I changed my master cylinder, and I wanted to bleed the brakes and abs..... I bleed my brakes properly and they work fine..... My problem lies within my abs system.
eagle458
Feb 3, 2014 10:24 PM
lak8
May 2, 2008 02:40 PM
bonh
Jun 28, 2007 12:15 PM
jonzel
Jul 27, 2005 03:29 PM
