check engine light
Old Aug 17, 2005 | 08:22 PM
sickofitall1113's Avatar
Default check engine light
how do you manually turn off the check engine light?
Old Aug 17, 2005 | 08:25 PM
93_teg_CT's Avatar
Default Re: check engine light (sickofitall1113)
Uplug battery terminals, hook em back up.
Old Aug 18, 2005 | 05:46 AM
xteg95's Avatar
Default Re: check engine light (93_teg_CT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_teg_CT &raquo;</TD></TR><TR><TD CLASS="quote">Uplug battery terminals, hook em back up.</TD></TR></TABLE>
that wont "manually turn it off" ... that only resets the ODB test, the light will come back on after the diagnostics are finished... ~50 miles. And you cant just turn that light off...
Old Aug 18, 2005 | 09:39 AM
Default Re: check engine light (xteg01)
you CAN just turn it off. i just did it. you turn the key to accessory then take out the backup fuse under the hood in the small fuse box near the battery. a 7.5 amp fuse. turn the car off. put the fuse back in. all done.
Old Aug 18, 2005 | 10:31 AM
xteg95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sickofitall1113 &raquo;</TD></TR><TR><TD CLASS="quote">you CAN just turn it off. i just did it. you turn the key to accessory then take out the backup fuse under the hood in the small fuse box near the battery. a 7.5 amp fuse. turn the car off. put the fuse back in. all done.</TD></TR></TABLE>
umm all that does it reset the ecu...read my above post, your CEL will be back on within a couple days. ya your welcome for the tip.
Old Aug 18, 2005 | 11:00 AM
so it will turn it off for the same amount of time as disconnecting the battery terminal? yea it was probably a waste of time then
Old Aug 18, 2005 | 11:44 AM
xteg95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sickofitall1113 &raquo;</TD></TR><TR><TD CLASS="quote">so it will turn it off for the same amount of time as disconnecting the battery terminal? yea it was probably a waste of time then</TD></TR></TABLE>
exactly
Old Aug 18, 2005 | 01:34 PM
crix868's Avatar
i have a better idea....jus take out the cluster an pull out the bulb it'll never come on again
Old Aug 18, 2005 | 01:58 PM
LSvtec03's Avatar
Default Re: check engine light (crix868)
why would you want to turn it off that way?? don't you know it means something is wrong and that you're ignoring the problem, potentially making it worse?
Old Aug 18, 2005 | 03:03 PM
ckyguy's Avatar
however if you know why it's on, and the reason doesn't really matter to you, having no bulb will tell you as much as having a bulb since neither will give you NEW reminders. And since the CEL on is annoying, I'd take out the bulb and just check the code(s) every now and then.
Old Aug 19, 2005 | 11:03 AM
crix868's Avatar
Default Re: check engine light (LSvtec03)
if u think i was serious i'll jus be quiet n not laugh
Old Aug 19, 2005 | 11:21 AM
LSvtec03's Avatar
Default Re: (ckyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ckyguy &raquo;</TD></TR><TR><TD CLASS="quote">however if you know why it's on, and the reason doesn't really matter to you, having no bulb will tell you as much as having a bulb since neither will give you NEW reminders. And since the CEL on is annoying, I'd take out the bulb and just check the code(s) every now and then.</TD></TR></TABLE>
that's great, until you have another problem come up, and then you have no easy way to figure it out.
do you really want to be running low on oil for whatever interval you use between randomly checking codes?
Old Aug 19, 2005 | 12:45 PM
the_23rd_letter's Avatar
Default Re: (LSvtec03)
You'll throw a CEL for not having enough oil? that kinda worries me, i used to burn oil pretty bad and had my motor run dry once and never had a CEL.
Old Aug 19, 2005 | 12:49 PM
xteg95's Avatar
Default Re: (the_23rd_letter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the_23rd_letter &raquo;</TD></TR><TR><TD CLASS="quote">You'll throw a CEL for not having enough oil? that kinda worries me, i used to burn oil pretty bad and had my motor run dry once and never had a CEL.</TD></TR></TABLE>
I don't think it does.
Old Aug 19, 2005 | 12:53 PM
Default Re: (xteg01)
i freaking hope not, otherwise my sheet is totally busted.
Old Aug 19, 2005 | 01:14 PM
LSvtec03's Avatar
you can throw a code for oil pressure. no oil, no pressure.
Old Aug 19, 2005 | 01:15 PM
son of a... so why wouldnt i get a CEL? is my ECU f-ed?
Old Aug 19, 2005 | 01:25 PM
freakasis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">
do you really want to be running low on oil for whatever interval you use between randomly checking codes?</TD></TR></TABLE>
he said that it would not give a "NEW" warning, if your light is on and you know why, what happens if it throws another code? nothing. you wont know unless you check it every once and a while anyway, so just take the bulb out it will get the light off and have no unsidirable effect IF you have a code on and dont care about it. but if you didnt have a code on why would you wanna turn it off?
Old Aug 19, 2005 | 01:35 PM
jay_96teg's Avatar
Default Re: (freakasis)
You people a ******* stupid, just take it to a garage and have them turn the light off. If you fixed to problem, any garage will turn the light off for free. All they need is a scan tool.....If the garge does emission testing, the emission machine has an obd2 diagnostic mode that can turn off the light too....this may take 10 minutes at the most.....problem solved.
Old Aug 19, 2005 | 02:21 PM
Default Re: (jay_96teg)
yea but (correct me if im wrong Sickofitall1113) i dont think hes fixed the problem, he just wants to turn off the light. hence the ensuing argument. and calling people ******* stupid probably isnt the best way to get them to realize they are doing something wrong, or to take your advice for that matter.
Old Aug 19, 2005 | 11:53 PM
LSvtec03's Avatar
can you at least tell us the code so we can tell you if you're ******* yourself or not?
Old Aug 20, 2005 | 07:46 AM
. a d a m's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">why would you want to turn it off that way?? don't you know it means something is wrong and that you're ignoring the problem, potentially making it worse?</TD></TR></TABLE>
I don't get it either.
Its like an airline pilot saying "**** I wish this fuel guage would go off"
Old Aug 20, 2005 | 10:56 AM
B18C_DD's Avatar
Default Re: check engine light (Sh!ttyLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sh!ttyLS &raquo;</TD></TR><TR><TD CLASS="quote">Its like an airline pilot saying "**** I wish this fuel guage would go off" </TD></TR></TABLE>
Hahahaha.
http://www.c-speedracing.com/faq/06.php
Gives instuctions on how to check the code. Codes link are at the bottom of the text. Figure out what CEL your throwing then fix it. Reset your ECU and after it's done with the diagnostics test in 50 miles the light should be out of your life. For now that is.
gsilnc
Jan 16, 2009 04:16 AM
jdmunzip
12
Sep 4, 2006 08:47 PM
asianalbutt
Sep 19, 2005 03:17 PM
10KrpmS2K
Honda S2000
Aug 11, 2005 07:36 PM
awalk2005
Jul 10, 2003 12:18 AM
