shift knob....
Old Aug 15, 2005 | 05:25 PM
mattdenali's Avatar
Default shift ****....
Anybody know how to make my shift **** point straight?!?! It's a grex **** and it points to the upper right side of the car...anybody know any easy ways to fix that?
also while on the subject, does anybody know any easy ways to make the shift boot stay connected to the ****?
Old Aug 15, 2005 | 06:12 PM
tegdude227's Avatar
Default Re: shift ****.... (mattdenali)
just tighten it as hard as u can thats wat i did with mine and it worked fine
Old Aug 15, 2005 | 06:58 PM
mattdenali's Avatar
Default Re: shift ****.... (tegdude227)
I've tried! I still have a looong ways to go untill it's straight.
Any other suggestions?
Old Aug 15, 2005 | 07:19 PM
zeroz's Avatar
use lock tight and twist it on till its straight but not to the point where its crooked and way tight and let the lock tight dry........ lol jk i duno
Old Aug 15, 2005 | 07:50 PM
mattdenali's Avatar
someone please help!!!
Old Aug 15, 2005 | 09:08 PM
happy_guy's Avatar
you need a bolt that goes under the shift **** to keep it from moving once you get it traight. but it will make your shift **** taller
Old Aug 15, 2005 | 09:15 PM
AllMotorDan's Avatar
you don't need a bolt....shove paper in the bottom of the shiftknob and tighten it all the way....if its not where you want it add more paper. Worked for me and my skunk2
Old Aug 17, 2005 | 12:03 AM
mattdenali's Avatar
Default Re: (SpoonSirG)
alright! got the shift **** straight!
my friend just goes lemme see and starts messing with it, next thing I know it's straight!
hah, now, how the hell do i get the shift boot to stay connected to the ****!
Old Aug 17, 2005 | 12:15 AM
Moogen Powah's Avatar
Default Re: (mattdenali)
You could try zip ties. Or maybe try this method: Click
Old Aug 17, 2005 | 06:39 AM
Sijray21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattdenali &raquo;</TD></TR><TR><TD CLASS="quote">alright! got the shift **** straight!
hah, now, how the hell do i get the shift boot to stay connected to the ****!</TD></TR></TABLE>
i kinda ghetto fab-ed electrical tape thick enough so the boot wouldn't drop down -- you can set it wherever you want. Ghetto, but it works.
Old Aug 17, 2005 | 08:26 AM
integra_twinz's Avatar
loc-tite is definitely the solution for the shift ****.
Old Aug 17, 2005 | 09:25 AM
Cliffjumper2's Avatar
Default Re: (Moogen Powah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Moogen Powah &raquo;</TD></TR><TR><TD CLASS="quote">You could try zip ties. Or maybe try this method: Click </TD></TR></TABLE>
that looks worse than having the boot sag.
I found a different kind of solution.
I took a piece of tin, and cut it round, then drilled a hole in the middle, big enough to fit over the threaded part of the shift lever, but not big enough to pass over the ridge and onto the main part of the shift lever.
Then put the boot back on, and the round tin can be bent and shaped to hold up the boot as well as give it some fullness at the top keeping it snug at the shift ****.
I should post some pics.
Old Aug 17, 2005 | 12:40 PM
RicharDC4's Avatar
Default Re: (Cliffjumper2)
i dont know what is wrong with all of your boots but with mine, all i have to do is losen my shift ****, pull the boot up to the **** then hold it ther while i tighten the **** back down and it stays where it should.
Old Aug 17, 2005 | 12:52 PM
fbmsucks's Avatar
good advice, i just rolled a few rap-a-rounds of electrical tape then shoved the boot over the tape, holds good, look good.
Old Aug 17, 2005 | 01:21 PM
5 Speed AP2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonSirG &raquo;</TD></TR><TR><TD CLASS="quote">shove paper in the bottom of the shiftknob and tighten it all the way....if its not where you want it add more paper. Worked for me and my skunk2 </TD></TR></TABLE>
EXACTLY! Same here.
Old Aug 17, 2005 | 08:28 PM
mattdenali's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cliffjumper2 &raquo;</TD></TR><TR><TD CLASS="quote"> that looks worse than having the boot sag.
I should post some pics.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fbmsucks &raquo;</TD></TR><TR><TD CLASS="quote">good advice, i just rolled a few rap-a-rounds of electrical tape then shoved the boot over the tape, holds good, look good. </TD></TR></TABLE>
you guys have any pics?
Old Aug 17, 2005 | 09:05 PM
you guys have any pics?</TD></TR></TABLE>
I'll look for some
pfcle
Honda Civic (2006 - 2015)
May 17, 2007 08:55 PM
tnewhallSi
Mar 31, 2006 11:44 PM
andrewasf77
Nov 10, 2002 11:50 AM
