91 integra shifter problems
i have a 1991 acura integra and when i put it into gear (any gear) the shifter wobbles around like half as much as if its in neutral...i just put energy suspension bushings in it and it hasent done anything for the wobbleness ...can anyone help me with this crap
thanks
jake
thanks
jake
I just dropped my tranny and replaced the clutch and flywheel. When I pulled the tranny, I left the linkage at the tranny end attached and disconnected it from the shifter end. When I put everything back together, I noticed my stick was alot firmer with alot less play. It must have been loose before, but now that I retightened the bolts at the shifter and stabilizer everything is firm again. I don't think it is your tranny, I think the play might be at your shifter to shift rod bolt.
DirTyPreTTyThinGs
Aug 15, 2007 08:35 PM
scttydb411
Feb 12, 2004 09:01 PM
