another gauge cluster problem...
Old Aug 16, 2005 | 12:13 AM
carsonR's Avatar
Default another gauge cluster problem...
i tried searching and no luck. I have a 96 integra that had one of those block plates for the clock. I got a new clock and went to install it and realized the wires were to short. Couldn't get them to reach all the way. Being lazy like i am i decide to just lengthen them. I wasn't thinking clearly and tried to cut all the wires at the same time(bad idea). + touched - and now none of my gauges work nor do the e-brake light, cel, or abs light, but the battery light came on when the key was in the accessory position and the background lighting still worked. I checked my fuses. Did i miss one or did i fry some circuit on the cluster?
TIA
Modified by carsonR at 1:32 AM 8/16/2005
Old Aug 16, 2005 | 03:58 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: another gauge cluster problem... (carsonR)
Check fuse 15 in your underdash fuse box. Check the backup fuse in your engine bay fuse box.
Perez_cb7
Jul 23, 2013 10:32 AM
f20cmx5
Jul 4, 2011 07:12 AM
enzozenuni
Dec 24, 2006 12:20 AM
TougeCoupe
May 18, 2005 05:12 PM
BoostedSi
Feb 23, 2003 08:59 PM
