threads on valve cover?
Old Dec 25, 2005 | 08:30 AM
MISFITofMAGIC's Avatar
Default threads on valve cover?
i just got my integra and im trying to figure out what is wrong with it this morning i went to pull the valve cover and 2 of the heads on the screws broke off since they are a lil rusty. i use rust eater and some lube. 2 are broekd off and i want to know if i can try to screw th rest off and hope they dont break or are the screws threaded into the valve cover too? is there threading inside the valve cover holes?
thanks.
Old Dec 25, 2005 | 09:41 AM
rdssk8rcs1's Avatar
Default Re: threads on valve cover? (MISFITofMAGIC)
nope no threads in on the valvle cover but sometimes those caps that are right under the bolts get jammed up real tight but none of that should effect you taking off the bolts just after you unbolt them all make sure you take off the caps before lifting up the valvle cover because there small and black so there easy to loose
be sure not to over tighten then when putting them back on or you will break the rest of the threads
Old Dec 25, 2005 | 09:46 AM
Default Re: threads on valve cover? (rdssk8rcs1)
thank you.
now i can go get this off.!!!
merry crisrtmas.
Old Dec 25, 2005 | 09:47 AM
Lauj87's Avatar
get a small punch and a hammer...and start turnin it little by little..i had to do this to its a bitch!
Old Dec 25, 2005 | 10:21 AM
well it was the timing belt.
illmatic118
11
Mar 17, 2009 09:31 AM
ITR32
Jul 27, 2007 06:09 AM
Import Prelude
Apr 18, 2007 02:50 PM
charjacq
Jan 29, 2004 04:24 PM
kreamy
Oct 2, 2003 06:43 AM
