Engine Trouble
Old Dec 24, 2005 | 09:15 AM
cazper8890's Avatar
Default Engine Trouble
Hey does anybody no why my motor sort of stuters when i accelerate it could it be a valve or a spun bearing
Old Dec 24, 2005 | 11:13 AM
watsvtecEK's Avatar
Default Re: Engine Trouble (cazper8890)
whens the last time you had a tune up?
Old Dec 24, 2005 | 04:12 PM
puffsef's Avatar
Is it idling rough or making a loud noise.
Old Dec 26, 2005 | 11:01 PM
cazper8890's Avatar
Default Re: Engine Trouble (puffsef)
when u accelerate it sort of stutters and its just a loud noise i can smell the gass runing mad rich blue smoke comes out the exhaust could it be timing off or a messed up fuel ingetor or spark plug ?
Old Dec 26, 2005 | 11:06 PM
DarkDragon's Avatar
blue smoke is oil, so oil is leaking inot the combustion chamber somehow. Check ur timing on both the ignition and valves. Check inside ur dissy capa nd see if its all corroded up, wires and plugs could also make a motor studder. Fuel filter, low pressure, bad pump could make it run lean but u said u smelled fuel, so it sounds really rich.
94XJ4Door
Honda Civic (2001 - 2005)
Apr 7, 2013 11:15 AM
emotionisdead
Mar 14, 2010 08:46 PM
david
Dec 2, 2005 09:18 AM
qboi85
Jun 19, 2005 08:29 AM
gsr96
Apr 3, 2003 11:32 AM
