Shaking question
Old Dec 23, 2005 | 07:19 AM
SlowSOHC-T's Avatar
Default Shaking question
Ok, i have a question for you guys. Here lately when i accelerate, my front end shakes and than goes away after a certain RPM....usually anything under 4k the front end shakes (i can feel it in my feet and so can my passenger)...But after i accelerate or get up to a certain speed it doesn't do it. Or if i creep into the gas it doesn't do it. The steering wheel doesn't shake at all, its just in my feet. I was thinking along the lines of ball joints.....
Any Ideas...
-Andru
Old Dec 23, 2005 | 09:18 AM
.:JEROME:.'s Avatar
Default Re: Shaking question (IWANTAHB)
Check your motor mounts
Old Dec 23, 2005 | 09:25 AM
EJ1 wilcox's Avatar
Default Re: Shaking question (.:JEROME:.)
Is it your motor that's shaking?
Does it shake at idle?
Mine was doing this (shaking at idle), I did a compression test and found out I had uneven compression, which caused the engine to shake at low RPMs. It was fine above 1500 or so, but below that it would shake a bit.
You might want to do a compression test just to be sure.
Old Dec 23, 2005 | 09:30 AM
M Coop's Avatar
If it shakes only under hard acceleration, I'm thinking it's one of your CV shafts. You can usually tell which side it's coming from if you pay close attention to which side is shaking worse. Other major possibility is maybe a wheel is out of balance but that usually changes with speed but not based on how hard you're accelerating. Other two guys could be right too, but I'd start with the CVs, if the boots are torn and have slung grease everywhere I'd be almost certain that was it.
Old Dec 23, 2005 | 09:45 AM
Dartanian's Avatar
Default Re: Shaking question (M Coop)
You have a bad inboard CV joint. I had the same problem and I tried everything including the motor mounts, alignment, rotors, etc, but the problem ceased when I replaced the bad axle.
Old Dec 23, 2005 | 10:22 AM
SlowSOHC-T's Avatar
kool....i will check the axles. Its the driver side that shakes the most. I replaced both of them not even 4months ago...Oh well i will replace them and find out for sure.
-Andru
Old Dec 23, 2005 | 11:25 AM
SlowSOHC-T's Avatar
Another question: How big of a difference is the Non-ABS axles to teh ABS axles? I have an extra set of Non's at the house, and thought about swapping them out. Just to test it....If its a big difference, i will just go and buy some..
Old Dec 28, 2005 | 06:31 PM
.:JEROME:.'s Avatar
The only diff is the little ring on the end. This is what the ABS computer reads to see how fast each wheel is moving. They should come off your old axles and pop onto the new axles. I have never tried to run a car without the rings but I wouldn't.... It might freak the ABS ECU out because it will see the back wheels moving and not the front.
drewcandraw
11
Jun 5, 2005 12:21 AM
HondaUser
May 29, 2003 07:25 PM
CRAPBUCKET
Nov 19, 2002 12:19 PM
98lude
Jul 27, 2001 07:29 PM
