Engine problems(burning water?)
Old Dec 25, 2005 | 02:22 PM
turbopsi's Avatar
Default Engine problems(burning water?)
I keep getting low on water, and my engine overheats.
I don't see any leaks in the radiator or anything, and "snot" keeps forming under my oil cap. Also, if air comes out of the valve cover when I open up my oil cap when it's running, does that mean my rings are shot?
Is this a cracked head or blown headgasket problem of some sort? Am I burning water?
I just went to the car wash, and it overheated only when idling, but when I give it gas and all that, it doesn't seem to overheat..
WTF is wrong with this car...
I want to rebuild it, but I'm on a budget and this is my only ride, I don't know where to start..
Old Dec 25, 2005 | 04:13 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default Re: Engine problems(burning water?) (turbopsi)
first, check your radiator cap to see if any pressure/steam is escaping from the radiator, and your water pump may be going out since when you gas your motor, the temp goes down. not really shore. but hey.. worth a try..
Old Dec 25, 2005 | 05:18 PM
.Kevin.'s Avatar
Default Re: Engine problems(burning water?) (ohsnapzafingcu)
otherwise i would say headgasket but if not that i would say check your thermostate (sp)
Old Dec 25, 2005 | 05:27 PM
ProjectLSVTEG's Avatar
Default Re: Engine problems(burning water?) (Slow_CvC99)
Have you made sure all the air was bled out of the system? I'd suggest going and having a cooling system pressure test done. IYou can get them done at Midas. My store doesnt charge for them usually, but I think most others charge $20.00.
90dxcrx
Apr 5, 2012 02:30 PM
Null zahlen
19
Sep 14, 2009 02:10 PM
dragaholic
Mar 13, 2008 09:39 AM
Eibach95Civic
Aug 17, 2006 05:03 PM
Oracle17
Oct 10, 2003 09:44 AM
