help!!!!
Old Dec 25, 2005 | 06:53 AM
petergriffen's Avatar
Default help!!!!
ok well i had my dash lights go out so i pulled the fuse that was broken. and i went to Advanced auto and got a 10 amp fuse to match the one i pulled. but the one i bought was smaller size fuse but still same amp . now me being in a hurry just put it in and tried to start my car ..... Nothing . car didnt start , didnt even make a sound . so i put the old broken fuse back in thinking it would start but yet again nothing but once i pop start it its fine runs great . plrase any advice
Old Dec 26, 2005 | 04:18 PM
sooo_slow's Avatar
New User
Default Re: help!!!! (petergriffen)
Are you sure you pulled out the right fuse? I thought when I replaced mine, it was a 15 amp..
And there are usually spare fuses in the fuse box, just read the back of the cover to find out where they are located.
Old Dec 26, 2005 | 05:41 PM
T.J.'s Avatar
the fuse you pulled was it from the box under the hood or inside the car?
Old Dec 26, 2005 | 08:23 PM
DC2-TEG's Avatar
Default Re: help!!!! (T.J.)
u try to make it sound like advance auto fucked up ur day....
dont hate on my employer!
Old Dec 27, 2005 | 12:12 PM
Default Re: help!!!! (DC2-TEG)
well somehow how it ended up being my ignition switch. but now my dash lights still dont come on . could it be the dimmer switch?
Old Dec 27, 2005 | 03:55 PM
sooo_slow's Avatar
New User
Possibly, but I'd think more towards a fuse. Did you check the panel lights fuse?
Old Dec 27, 2005 | 06:17 PM
Default Re: help!!!! (sooo_slow)
ive checked all of the fuses but to be safe i can check again . and another question (which is kind if a dumb one) but is there a positvie or negative on a fuse i dont think there is right?
Old Dec 27, 2005 | 06:35 PM
gsr dood's Avatar
theres no pos and neg on fuses. i would put 100$ down and make a bet that its ur ignition fuse under ur hood. look in the fuse box near ur battery and its a 50 amp (i believe) fuse. if ur ingiton lights dont come on and ur car wont click at all....its 100% ur ign fuse. tell me wat happens
Old Dec 28, 2005 | 05:55 AM
Default Re: help!!!! (gsr dood)
well the igntion switch went bad so that why the car didnt start but i by passed it so i didnt have to buy a new ignition switch. i can check under the hood. i dont think that the problem and also like when i leave me lights on and open the door its doesnt beep anymore to tell me i left my lights on.
Old Dec 28, 2005 | 06:03 AM
projectac's Avatar
check the instrument panel fuse i think its a 7.5 amps fuse might be .
had the same problem some time ago.
Old Dec 28, 2005 | 06:31 AM
Default Re: help!!!! (projectac)
that is the fuse but its a ten . so i went to out and bought a pack of ten amp fuses the go in ok but it i leave the fuse cover off , and as soon as i turn my dash lights on i hear and see a pop of the fuse i just replaced and it does this every time so now i have to go buy more fuses. but why should they be blowing every time i turn on the dash lights if its the same ampage as before? (this is getting agrivating)thanks to all who have helped so far
Old Dec 28, 2005 | 07:08 AM
also i did a search and most people with the same problem say its a wire touching a grond wire. how do i check this
Old Dec 28, 2005 | 07:39 AM
projectac's Avatar
get ohm meter or multi meter and check the resistance from the load and line side
to ground.
Old Dec 28, 2005 | 08:12 AM
what
Old Dec 28, 2005 | 11:08 AM
aznd87's Avatar
yeaa just get a ohm metter and check it out
Old Dec 28, 2005 | 11:15 AM
Default Re: help!!!! (aznd87)
ok i got a ohm meter and will anyone give me a step by step on how to use it right to find my problem. please
monsterCHILD
Jan 6, 2011 04:28 PM
Crooner
Acura TL, RL & ZDX
Oct 22, 2008 08:51 AM
Bucktown
Audio / Security / Video
Mar 8, 2004 06:11 PM
sloweh3
Oct 31, 2003 04:58 PM
phathodna35456
May 20, 2003 08:04 PM
