flywheel how to?
Old Dec 23, 2005 | 10:57 AM
HondAcura's Avatar
Default flywheel how to?
how to you torque down your flywheel without it spinning?
Old Dec 23, 2005 | 10:58 AM
Jasper_db1's Avatar
Default Re: flywheel how to? (HondAcura)
Have someone hold the crank pully bolt.
Old Dec 23, 2005 | 11:02 AM
HondAcura's Avatar
Default Re: flywheel how to? (Jasper_db1)
if you dont have someone hold the crank pulley bolt, can the flywheel be torqued another way by one person?
Old Dec 23, 2005 | 11:14 AM
M Coop's Avatar
Maybe attach a breaker bar to the bolt (or a rachet with a pipe around it and lodge it against something (preferably not the master cylinder or anything fragile). Definitely have to torque down the crank bolt though, there's actually a tool that fits in the hex shaped hole in the crank pulley that would be best to hold it but since you probably don't have it, what I said above might work. Good luck
Old Dec 23, 2005 | 11:54 AM
HondAcura's Avatar
Default Re: flywheel how to? (M Coop)
THanks guys, all i did was attach two tranny bolts and stick a screwdriver in between torqued to specs 76 ft-lb.
Old Dec 23, 2005 | 12:02 PM
.water's Avatar
lol..pics? too late eh?
they sell those kit tho..$$$$$
Old Dec 23, 2005 | 04:30 PM
HondAcura's Avatar
Default Re: flywheel how to? (zzzkangzzz)
i'll try to describe...upper right side of where tranny bolts on to engine if you're looking straight at engine <U>from passenger side</U> of car. There are two bolt holes real close to each other. I bolted those with two Transmission bolts and stuck a wide screwdriver in between. I'd rather use the special tool though. will get if i gotta do it again. remember, <U>If</U> you wanna save time you can either; have the right tools, or have experience.
Old Dec 23, 2005 | 08:58 PM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondAcura &raquo;</TD></TR><TR><TD CLASS="quote">THanks guys, all i did was attach two tranny bolts and stick a screwdriver in between torqued to specs 76 ft-lb.</TD></TR></TABLE>
isn't this how it's done? haha
Old Dec 24, 2005 | 05:24 AM
ProjectLSVTEG's Avatar
Default Re: flywheel how to? (LSvtec03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">
its how i've always done it :
88 dx
13
Aug 19, 2005 10:30 AM
Ignitecivic
Mar 20, 2004 09:41 AM
LudeyKrus
Jan 3, 2004 05:56 PM
vultron
Aug 9, 2003 09:59 PM
baonest1
Nov 19, 2002 12:37 PM
