check this setup out!!
Old Dec 21, 2005 | 10:30 AM
DA-9mordef's Avatar
Default check this setup out!!
i have a da full interior flat black
b20block
gsr head
itr01cams
itr01valves
itr01springs
aem gears
b17tranny
act stage 1 clutch
b&m fuel regulator
i want to run pretty good low 14s
what do you guys think i need to tweek it up a little more??
Old Dec 21, 2005 | 10:42 AM
BuyImports2's Avatar
Default Re: check this setup out!! (DA-9mordef)
Nice plans. how are you going to tune it though?
Old Dec 21, 2005 | 12:19 PM
CNSK's Avatar
weather, track condition, proper driver, tires, 60ft time, and dyno tuning plays a big role in getting the time you want. You can have all that setup and run 16's all day and another driver can drive the same car and hit 13's......all depends.....practice, practice, practice.....
Old Dec 21, 2005 | 12:51 PM
teggy182's Avatar
you can get a lighter flywheel and also loose some interior. at least the spair and stuff like that. good luck
Old Dec 21, 2005 | 01:37 PM
rkrone's Avatar
get some bigger injectors and fuel management,
i ran 450cc's with my b20 (almost same set up) when it was NA with a tuned ecu, it pulled hard!!!
Old Dec 23, 2005 | 03:33 PM
GSRVTEC1's Avatar
Default Re: check this setup out!! (rkrone)
definitely higher comp pistons
vtec8200
Apr 6, 2009 12:48 PM
Easyslider01
Jul 1, 2005 11:11 PM
TripleBlackHatch
Mar 17, 2004 06:12 PM
a z n t a k
Jul 13, 2002 06:34 PM
Chip398193
Mar 4, 2002 08:52 AM
