map sensor cel and can't find the problem
Old Dec 21, 2005 | 05:05 PM
2000si's Avatar
Default map sensor cel and can't find the problem
this is a repeat post. i originally posted in the civic forum and thought i would give you guys a try.
i have a 1997 civic ex with a 1997 gsr swap and i have a cel on. it is the map sensor. it says that the voltage circuit is high. i figured it was a bad sensor so i replaced it. cel still comes on. i have a zex kit, comp cams, aem v2 cold air intake, 2.5 inch exhaust, an apex vtec controller, and cam gears.
the cell has alway been on but i have had no problems with drivability untill recently.
the problem i am having is sometimes the car boggs down when i accelerate from a stop. it doesn't do it all of the time though. also sometime my idle goes up to 1300 rpms instead of the normal 800 rpms. also the light doesn't come back on after i clear until about 6500 rpms.
i just put the stage one comp cams in this weekend and the problem is now becoming more consistent; however, the problem was present before the cams.
wtf?????? i am doing a search as well but nothing so far.
here is what i have gotten so far.
https://honda-tech.com/zerothread?id=1467613
Old Dec 22, 2005 | 09:01 AM
2000si's Avatar
Default Re: map sensor cel and can't find the problem (2000si)
anyone
HX35_Ek_Hatch
Jan 15, 2013 07:29 PM
happyabortion
17
Dec 15, 2008 09:33 AM
xASAPx
Sep 15, 2006 09:21 PM
2000si
Dec 22, 2005 09:00 AM
roninb18
Jan 16, 2003 10:30 AM
