quick transmission question..
Old Dec 21, 2005 | 08:55 PM
watsvtecEK's Avatar
Default quick transmission question..
i was changeing my wtf and i drained the fluid but i cant seem to get the the fill bolt off. it is on so tight and i cant get enough leverege. i cant fill it throu the vss becuse one of the heads on the bolts is snaped off. my question is can i fill it through the hole on the front of the tranny, it has a cap on it, i guess its the breather. Can i fill it there???? thanks
fast input please becuse i need to do this now i need to drive my car.
Old Dec 21, 2005 | 08:57 PM
watsvtecEK's Avatar
Default Re: quick transmission question.. (D 2da A9)
i have a 93 ls btw
Old Dec 21, 2005 | 09:15 PM
watsvtecEK's Avatar
damit, is it possible that the threads are backwards??? like loose is tight and tight is loose?? i just bent my rachet trying to get it off.. wow
Old Dec 22, 2005 | 05:23 AM
rkrone's Avatar
did you lube it up first? wd-40 or liquid wrench? that might help
if you go through the vss, then make sure you put in the right amount, i believe it is 2.1 qts. but don't quote me on that, check you manual
Old Dec 22, 2005 | 07:04 AM
watsvtecEK's Avatar
Default Re: quick transmission question.. (rkrone)
like i said, i cant fill through the vss becuse one of the heads on the bolts is snaped off, so i can not take it off. and i did use some penitrating lube. i am going to get a bigger rachet today and try it. dose anybody know if i can fill through the breather hole??
Old Dec 22, 2005 | 12:08 PM
watsvtecEK's Avatar
wow, i am shure someone knows... please i need an answer quick.
Old Dec 22, 2005 | 05:53 PM
watsvtecEK's Avatar
ttt.... can i fill the tranny fluid through the breather hole!!!!!!!!! ahhhh
Old Dec 22, 2005 | 06:37 PM
coot_er's Avatar
is that a cable speedo cable? if it is just pull out the cable and find a small funnel or small straw and fill it through there, no need to unbolt it.
Old Dec 22, 2005 | 07:14 PM
watsvtecEK's Avatar
Default Re: quick transmission question.. (coot_er)
i am wondering if i can fill it through here..
Old Dec 22, 2005 | 07:16 PM
watsvtecEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coot_er &raquo;</TD></TR><TR><TD CLASS="quote">is that a cable speedo cable? if it is just pull out the cable and find a small funnel or small straw and fill it through there, no need to unbolt it.</TD></TR></TABLE>
how do you take it off? just pull on it? i tryed that and it would not come out.
Old Dec 22, 2005 | 07:19 PM
coot_er's Avatar
on my b16a i just slide the rubber boot up and pull it straight out. i have read that there is some sort of pin, but i have never seen it on mine.
Old Dec 22, 2005 | 07:27 PM
Johnny_Rocket's Avatar
I filled my tranny through that breather hole... took forever but it worked
Old Dec 22, 2005 | 07:28 PM
namsoofabolus's Avatar
well...i got some leverage on mine...and lubed it...what i did was...i lubed it...slid my head to the back end of the car...and pushed the rachet with my foot....and it got loose.... im asian...this is how we do...lmao
Old Dec 22, 2005 | 10:33 PM
watsvtecEK's Avatar
Default Re: quick transmission question.. (namsoofabolus)
thanks.. finaly finished
1uncleanDA
Nov 13, 2007 03:11 AM
macsmurray
10
Jan 16, 2006 04:58 PM
InjectedSS
Dec 19, 2002 04:52 AM
cecknight
Nov 8, 2001 10:21 AM
