valves
Old Dec 23, 2005 | 11:14 PM
Baron55's Avatar
Default valves
i got a compression test done on the gsr and adjusted the valves because some were loose...
numbers on the compression 220,210,215,215....what you think?
after adjusting the valves, there is a ticking noise, not loud but noticable...the shop told me it was normal. A friend of mine just built his entire motor and he says he has the same thing....is this really normal???
Old Dec 23, 2005 | 11:15 PM
Dartanian's Avatar
Default Re: valves (Baron55)
Compression looks good. Is the car stock?
Old Dec 23, 2005 | 11:25 PM
Baron55's Avatar
just i/h/e
Old Dec 23, 2005 | 11:27 PM
Dartanian's Avatar
Default Re: (Baron55)
The ticking isn't normal. A valve lash adjustment should get rid of the ticking, not induce it.
I would drive it a little bit and see if the ticking goes away. If it doesn't, it could be something wrong with the rocker arms or lost motion assemblies.
Old Dec 24, 2005 | 06:17 AM
Baron55's Avatar
any other ideas?
Old Dec 24, 2005 | 07:57 AM
blkb18's Avatar
slight ticking on a cold engine that goes away when warm isn't a problem, one or some of the valves are a bit loose. Slightly loose valve adjustment won't hurt anything, too tight will.
Old Dec 24, 2005 | 08:02 AM
CBURKE's Avatar
Yeah the slight ticking is ok. You have to think, there is metal touching metal, your gonna hear something.
SinsEvil666
49
Oct 15, 2008 11:04 PM
B20inDCinLBC
Oct 21, 2006 09:40 PM
OBRJosh
Aug 9, 2006 05:25 PM
lakerschamp2000
Dec 19, 2004 12:59 PM
SoSoJeff
Oct 24, 2002 08:53 PM
