ABS leak....Help needed
Sup guy...........car has another problem again...my ABS is leaking can't find where it leaking from...anybody have any problem like this before??...should i buy a new one or fix it???..and wats the cost of the new one...anyone knows??..aite thanks
Pull the ABS light codes like you would a CEL (see the FAQ thread in the Integra forum).
You most likely have a faulty solenoid valve in the ABS modulator under the hood. Your ABS is not technically leaking, it is just overflowing the reservoir when the high pressure chamber discharges into the reservoir.
ramz7887
Mar 22, 2007 07:51 PM
... its rather annoying soo i d/c the abs for the time being
