Differnce between B18A1 and B18B1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenMojo »</TD></TR><TR><TD CLASS="quote">I think a better question would be the difference between the two versons of the B18A1, 90'-91' & 92'-93'? The later verson has 140HP while the B18B1 has 141HP. So I've been told.</TD></TR></TABLE>
yes i would like to know why the 94 b18b has 142...whats the difference? i thought the engines were pretty much identical
you answered your own question. "pretty much" = operative words
they added a solid 6 more lb/ft of tq... which changes the whole thing. c'mon, we have hondas.
my little doll-size hand wrenching makes more torque than the car the bolts are on...
94-00 Ls / Rs
Gs B18B1 3G - DC 1834 9.2 : 1 142 @
6300 rpm 127 lb/ft @
5200 rpm USA
90-91 ALL B18A1 2G - DA 1834 9.2 : 1 130 @
6000 rpm 121 lb/ft @
5000 rpm USA
92-93 all but GS-R B18A1 2G - DA 1834 9.2 : 1 140 @
6300 rpm 121 lb/ft @
5200 rpm USA
Modified by B18Ch1ck at 10:43 AM 7/18/2007
94-00 Ls / Rs
5200 rpm USA
5000 rpm USA
5200 rpm USA
one the cams in the 94 up are a little bigger (exhaust) ,94 up intake manifold are more smoother,other than that its the same
that is why i use the 94up cams/im/tb on my 93 b18a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenMojo »</TD></TR><TR><TD CLASS="quote">I should get same if not better results if I run the 94 and up cams/im/tb on my 90' B18A1?</TD></TR></TABLE>
yea you will i noticed a differnt in mid to top end power
The cam lobes on the B18B on the exhaust cam have a .2" larger cam lobe height, along with the freerer flowing IM. The 10hp difference between the90-91 to 92-93 B18A's I think has to do with the switch from OBD-0 to OBD-1, probably better fuel management and things.
jeremy.
Jul 18, 2004 09:19 AM
