Leak down test issues.
Old Jul 16, 2007 | 11:04 AM
1badteg's Avatar
Default Leak down test issues.
I have done two sepereate leak down tests on my lsvtec and i have pulled horrible numbers. From cylinder 4 to 1: 100, 20, 100, 20. The engine sounds good and it runs well around town. It does however sound like a WRX at start up. So it makes me think that not all cylinders are firing. Now to the confusing part, on the leak down test the air escapes from the spark plug well. Possibly thru the spark plug well seal? I don't have extensive experience but enough to know that somethings wrong. I just replaced my valve seals with supertech seals. Not burning oil either.
Modified by 1badteg at 12:27 PM 7/16/2007
Old Jul 16, 2007 | 11:16 AM
LordAphotic's Avatar
did you do a compression test before this?
Old Jul 16, 2007 | 11:28 AM
1badteg's Avatar
Default Re: (LordAphotic)
yes, compression test was 240 across the board. Forgot to mention that.
Old Jul 16, 2007 | 12:51 PM
hmm 240 across the board ... you didnt even need a leakdown test if the compression test is good then the leakdown will always be good...
so heres what i think you did wrong... did you make sure to have each piston at TDC when you tested it?
its easy to overlook if its your first time with the leakdown.
Old Jul 16, 2007 | 02:00 PM
1badteg's Avatar
I did everything right. When you do a compression test it really doesnt let air escape from the compression tester, so the guage will increase until it reaches its max (mine being 240) then it stays. A leak down test shoots a continuous amount of air into the cylinder. Each time I checked a cylinder I had it at TDC. I am leaking air somewhere and its not coming from the intake or exhaust nor the radiator.
BUMP
SilkyJohnson
13
Feb 15, 2011 05:54 PM
humboldt_skim
May 31, 2008 08:18 AM
sinister357
Aug 25, 2007 10:05 PM
Sport_Injected
Aug 16, 2004 09:06 PM
Propulsion
Jun 5, 2002 11:48 PM
