One big electrical problem...
I have a stock 95 teg gsr, with about 145k on it. Runs like a champ except the driver side window wont roll down unless i push on the top of a fuse in the fuse box. If i push the second fuse from the left, on the top row, it will work. Also have to do this to use sunroof. Sucks ***!
My right side head light (both low and high) are out as well, but my left is fine. The dome light comes on intermediately but that has been a problem before this started. So, any help is greatly appreciated!!
I have no idea. its probably not the problem. Just seems odd that it works when you press on the fuses, maybe even replace the fuses first....
So you are absolutely positive the problem goes away when you push down on the fuse? It is rather rare for the fusebox to go bad, as it has oversized contacts for the actual fuses, but it is definitely not impossible.
si0385.
20
Apr 17, 2006 08:12 AM
