VTEC Kick In?!
Old Jul 16, 2007 | 01:37 PM
jordan_civic's Avatar
Default VTEC Kick In?!
Hey, I was thinking of going to a local tuning shop and see if they could maybe change the butterflys opening time to earlier...maybe before the vtec kicks it. Anyone have any thoughts?
thanks
Jordan
Old Jul 16, 2007 | 01:42 PM
climb_on's Avatar
Default Re: VTEC Kick In?! (jordan_civic)
if you have insects in your engine you have more serrious things to worry about...try RAID.
but serriously what are you talking about?
Old Jul 16, 2007 | 01:45 PM
98teggy-gsr's Avatar
vtec controller?
Default Re: VTEC Kick In?! (climb_on)
I am talking about the butterly valves on the intake manifold that open up at 5800 rpm..i would like to change the time to before the vtec kicks it. I think it would make it better but idk...
Old Jul 16, 2007 | 01:46 PM
Blahblah718293's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by climb_on &raquo;</TD></TR><TR><TD CLASS="quote">if you have insects in your engine you have more serrious things to worry about...try RAID.
but serriously what are you talking about?</TD></TR></TABLE>
learn the engine, then speak. i dont really understand everything myself but i figure if it was efficent to open the butterflies sooner, they would come that way.
Old Jul 16, 2007 | 01:51 PM
Default Re: VTEC Kick In?! (Blahblah718293)
i thought if you started getting more air in there before vtec kicked it would be way better boost...
Old Jul 16, 2007 | 01:54 PM
DC2R_JOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jordan_civic &raquo;</TD></TR><TR><TD CLASS="quote">i thought if you started getting more air in there before vtec kicked it would be way better boost...</TD></TR></TABLE>
Thats why you go buy a skunk2 intake manifold
Old Jul 16, 2007 | 01:55 PM
Default Re: VTEC Kick In?! (DC2R_JOE)
ok. Tell me about the skunk 2...havent heard much. Dont know anything about it...
Old Jul 16, 2007 | 01:56 PM
97integraLS911's Avatar
no. Honda designed vtec to engage exactly when it does because if u open it to soon u actually lose power. It will be perfectly fine with boost exactly where it engages now. good luck
Old Jul 16, 2007 | 01:57 PM
climb_on's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blahblah718293 &raquo;</TD></TR><TR><TD CLASS="quote">
learn the engine, then speak. i dont really understand everything myself but i figure if it was efficent to open the butterflies sooner, they would come that way.</TD></TR></TABLE>
When vtec engages the vtec lobes on the cam forces more air in and out of the cylinder. having the throtle plate (or butterflies as Blahblah says) fully open up prior to engaging vtec wouldn't be beneficial because the cylinders will not "need" that extra air. Just like therese is no point in upgrading your intake manifold with stock cams...
but don't listen to me cause blah blah says i need to learn about the engine
Old Jul 16, 2007 | 02:01 PM
but don't listen to me cause blah blah says i need to learn about the engine</TD></TR></TABLE>
yep, i was going to say that but i wasnt sure on all the facts and i didnt want to sound like a newb if i was wrong. anyway, i thuaght you were joking about the butterflies, h-t's been newby like that lately.
actually i just read this yesterday and it may help a little
http://www.team-integra.net/se...D=246
but again, it is the way it is to keep a flat torque curve, said in the article.
Old Jul 16, 2007 | 02:02 PM
tommy_h's Avatar
The "butterfly valve" your talking about is actually in the throttle body and it opens as you apply the accelerator. There are no butterfly valves in the intake manifold!!!!!!!!
Old Jul 16, 2007 | 02:08 PM
deftonerider's Avatar
their ARE butterflies in the intake manifold and if you remove them then or open them earlier you will lose power unless you tune.
i had put a skunk2 manifold on my gsr and when i drove it lost power till the computer "thinks" the butterflies are open.
adjusted that with tuning and now i'm very happy
on the underside of the int mani their is a vacuum box with a sensor that controls the butterflies. as far as adjusting it i wouldn't know
climb_on's Avatar
Default Re: VTEC Kick In?! (tommy_h)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommy_h &raquo;</TD></TR><TR><TD CLASS="quote"> The "butterfly valve" your talking about is actually in the throttle body and it opens as you apply the accelerator. There are no butterfly valves in the intake manifold!!!!!!!!</TD></TR></TABLE>
thats what my first post was trying to point out
what people always refer to as butterfly is actually the throttle body or the throttle body plate to be more exact. and yes it is seperate from the manifold.
to the original poster. something you could consider is a vtec controler that will set vtec to hit sooner if you want that power before 5800 as you said. also to consider down the line is a intake manifold and bigger throttle body (type R), but all that is pointless with stock cams. bigger cams are thirsty for more air...so give them more air with the new manifold.
Old Jul 16, 2007 | 02:11 PM
Default Re: (deftonerider)
ok. So it wouldnt be good to have it tuned to open earlier. Or maybe at 5000 instead of 5800. Like a little earlier....
Old Jul 16, 2007 | 02:13 PM
Championship's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jordan_civic &raquo;</TD></TR><TR><TD CLASS="quote"> I think it would make it better <FONT SIZE="5">but idk</FONT>...</TD></TR></TABLE>
<FONT SIZE="5"><FONT COLOR="red">EXACTLY!</FONT></FONT>
if you want to mod something, start by exhaust and your intake. then make up your mind if your going n/a or force induction. and search!
climb_on's Avatar
Default Re: (jordan_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jordan_civic &raquo;</TD></TR><TR><TD CLASS="quote">ok. So it wouldnt be good to have it tuned to open earlier. Or maybe at 5000 instead of 5800. Like a little earlier....</TD></TR></TABLE>
leave it alone, honda engines are precise tuned machines.
likes stated before it was benificial to open early those crazy japonese enginers would have tought of it.
thats my 2 cents
Old Jul 16, 2007 | 02:14 PM
ok. Does anyone wanna help me out and tell me all the stuff that i should get and why? What to get first and what all to get. I think my gsr is stock exhaust manifold. Is it ok?
Old Jul 16, 2007 | 02:15 PM
header, coldair, exhaust, Skunk 2/blox intake manifold.
TUNE
done
climb_on's Avatar
Default Re: VTEC Kick In?! (Championship)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Championship &raquo;</TD></TR><TR><TD CLASS="quote">
if you want to mod something, start by exhaust and your intake. then make up your mind if your going n/a or all motor. and search!</TD></TR></TABLE>
so no the original poster doesnt get even more confused here, n/a (naturaly asperated) and all motor is the same thing.
im pretty sure championship meant n/a or boost
Old Jul 16, 2007 | 02:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jordan_civic &raquo;</TD></TR><TR><TD CLASS="quote">ok. Does anyone wanna help me out and tell me all the stuff that i should get and why? What to get first and what all to get. I think my gsr is stock exhaust manifold. Is it ok?</TD></TR></TABLE>
Old Jul 16, 2007 | 02:18 PM
im pretty sure championship meant n/a or boost</TD></TR></TABLE>
haha yeah. boost!
to the OP, make up your mind if your going TURBO or N/A 'as stated above, its naturaly aspirated. which means nothing forced/crammed in the engine. alot will suggest turbo since its cheaper and will get you closer to high numbers on dyno with half the money....
anything you want to know will be on the top right corner. HENCE the search!
Old Jul 16, 2007 | 02:19 PM
Default Re: (Championship)
ok...any recommendations. I like ebay but i know its not a favorite for alot of u...
Old Jul 16, 2007 | 02:20 PM
i dont have enough money to go turbo. What if i got a cheap turbo kit on ebay and just replaced the blower.
Old Jul 16, 2007 | 02:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jordan_civic &raquo;</TD></TR><TR><TD CLASS="quote">i dont have enough money to go turbo. What if i got a cheap turbo kit on ebay and just replaced the blower. </TD></TR></TABLE>
DO NOT buy an e-bay turbo, i heard bad reviews.
just go with a header, cold-air...for now, if you want to go n/a you can go with camshafts. and pistons. and tranny etc.
search man, search!
anything you want to know is on the search option!
later
