installing tranny
Old Jul 15, 2007 | 10:40 AM
blakacintegra's Avatar
Default installing tranny
im having the hardest time putting my tranny back in after changing my clutch...is there anything someone can tell me to help, like any pointers or anything
Old Jul 15, 2007 | 10:44 AM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Default Re: installing tranny (blakacintegra)
Use multiple jacks to evenly lift the tranny into place. Or if you have one, use a cherry picker with the jack.
Once you get it remotely close into place, try to put in a few bolts and gently tighten to help pull & align the tranny in place.
Old Jul 15, 2007 | 05:53 PM
boostmywankle's Avatar
Default Re: installing tranny (CARMA_626)
i always find it succesful to use a jack under the tranny and jack it up while balancing the tranny on the jack once ur high enough, grab ahold of that bitch and push the imput shaft into the flywheel and wiggle the tranny back and forth while pushing, it should line up without to much problem. (then again, im a big kid and i just seem to manhandle it in.) Its also been a while sence ive down this work on the ground. lifts own you.
Old Jul 15, 2007 | 06:22 PM
skata89's Avatar
I use to dowls for the top two holes, that way it lines the tranny up pretty good then just twist it some to catch the teeth and push it on. Also it helps when you have more then one person working with youl.
Old Jul 15, 2007 | 09:48 PM
super jdm yo's Avatar
Default Re: (skata89)
just make sure you go in as straight as possible and don't let the transmission hang from the intermediate shaft that'll ruin your transmission internal
Old Jul 15, 2007 | 11:22 PM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
real easy ive done this tons of times get a buddy to help you hold it and carefully insert it and gently slide it in sometimes i did this on my own but if your weak sause dont do it
slo_ej8
Apr 8, 2008 05:04 PM
WGFletch4WS
May 30, 2007 11:08 AM
Acrappyhatch
May 12, 2006 08:27 AM
92CiviC4dr
Jan 18, 2006 01:49 PM
