secondaries not working ??
Does it rev beyond 6000 RPM? Have you looked at the vacuum actuator for the IAB during startup? It should close after the engine starts and reopen after the engine shuts off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poorhonda »</TD></TR><TR><TD CLASS="quote">how do the secondaries work</TD></TR></TABLE>
The IAB works by applying vacuum to the actuator at low RPM. At ~5750, the solenoid closes and the vacuum is removed. The actuator releases it vacuum through a filter on the solenoid.
Hi, CEL just came on and threw 2 codes =/ CEL 67 (catalyst system) and CEL 90 (evaporative emission control system).
Does anyone have any information on what to test/look for?
Edit- searched more and found the answer to CEL 90. My gas cap wasn't all the way tightened. I filled up days ago! Stupid Oregon gas attendent (not all, just the idiot working at Shell who can't turn it in 3 clicks!) Will reset the ecu and see if it comes back on later.
Modified by 13loody at 3:41 PM 5/20/2008
trooper0641
21
May 19, 2004 08:49 AM
