Check engine code 22
Old Mar 10, 2008 | 05:08 AM
thunderboy's Avatar
Default Check engine code 22
My car give my check engine code 22. That's mean the VTEC Oil Pressure Switch (1.8L GSR). What do I have to do? Change it or is there somenthing else that I can do??Do you know where to find this switch??Help me please.
Old Mar 10, 2008 | 05:49 AM
hatchling37's Avatar
Default Re: Check engine code 22 (thunderboy)
It's the little switch that's bolted to the VTEC solenoid. Take the solenoid off and remove the switch and clean out the whole thing. I'd replace the gasket, too, if it's haggard. Make sure it's clean and dry (if you use solvent- don't know if it can be used on the solenoid without being harmful) before you reinstall.
Dahhhbeed
14
Aug 27, 2016 03:08 PM
silverskateEF9
Apr 29, 2008 12:38 PM
preludefien
Feb 11, 2007 10:43 AM
93 accord H22a
Jun 15, 2004 11:45 AM
Snail Tuning
Sep 26, 2002 05:39 PM
