driver side mount question?
Old Mar 10, 2008 | 09:14 PM
pootie.teng's Avatar
Default driver side mount question?
i bought a rolling dc2 chasis and i rebuild my old lsv and dropped it in. everything went fine but the only thing i question is that the driver side mount is a little loose. what i mean by loose is there is a gap between the motor mount and the mount on the car. i can shake the motor back and fourth and see the driver side motor mount slide side to side a bit. seems like there is a gap no matter how hard i tighten the bolt like its missing a washer or something. anyone ever have this problem.
Old Mar 10, 2008 | 09:44 PM
UmbraDc2K's Avatar
Default Re: driver side mount question? (pootie.teng)
What mounts are you using?
Old Mar 10, 2008 | 10:02 PM
Default Re: driver side mount question? (UmbraDc2K)
stock...
Old Mar 10, 2008 | 10:10 PM
UmbraDc2K's Avatar
Hate to ask more questions but DA or DC stock mounts?
Old Mar 10, 2008 | 10:24 PM
dc2 stock mounts. looks like there is like a 2mm gap and i can rock the mount side to side on the bolt...
Old Mar 10, 2008 | 10:28 PM
UmbraDc2K's Avatar
Man, I just don't know then. I've never seen that unless it was the wrong mount. In the case if it was the wrong mount I would have used a few washers until I could upgrade to Hasport or Innovative. Best of luck to you, man. Hope someone else can help you better than I did.
endo617
11
Jun 28, 2008 12:18 AM
staticrex
Jan 14, 2005 03:34 PM
SwissChEz82
Nov 17, 2004 10:20 AM
TeGGY_LS
Nov 15, 2004 08:19 PM
Tire Monkey
May 1, 2004 12:38 PM
