starting????
Old Mar 9, 2008 | 09:03 AM
DA_RS's Avatar
Default starting????
i left my car sitting on the back of my house all winter, we pull it out the other day with a friend jump start car start fine, drive it around, battery charge start up fine next day drive it to the pump put some gas in it and two min down the road the car stalls and didn't start back on, what can be the problem?? is it fuel? i was thinking that might be some residues on gas lines??? any ideas? possible tests??
Old Mar 9, 2008 | 09:11 AM
lmike6453's Avatar
i would say start with fuel...if not that then do a full tune up with also replacing fuel filter, run fuel injecter cleaner and clean air filter
Old Mar 9, 2008 | 10:20 AM
BoSox46GSr's Avatar
Default Re: (lmike6453)
Yeah start with the cheapest fix. Because most if it, you'll need to do at some time or another. Now is as good a time as any. Then, if a tune up doesn't work, check your dizzy or alternator.
Old Mar 9, 2008 | 10:40 AM
DA_RS's Avatar
Default Re: (BoSox46GSr)
we tested the spark plug wires coming from the distributor and they didnt work, so im thinking its the distributor module. the thing is i dont know how to test it. the guy at the parts store told me that theres no way to test it so i wanna know if there is a way.
Old Mar 10, 2008 | 11:53 AM
DA_RS's Avatar
Default Re: (DA_RS)
anyone? i rly need to fix this!!
thanks
DA_RS's Avatar
Default Re: starting???? (DA_RS)
bump^^
Tim2179
Honda Civic (2001 - 2005)
Dec 9, 2010 12:18 PM
SOHC_civic_si
Oct 27, 2008 04:23 PM
misfits_skater
Dec 5, 2007 05:08 AM
viprcr1
24
Sep 8, 2006 12:26 PM
leebabin387
Oct 21, 2005 08:57 PM
