having temperature issues with the teg
Old Mar 9, 2008 | 01:54 AM
dumada9's Avatar
Default having temperature issues with the teg
i noticed that even after letting my car completely warm up, once i start driving, the temp gauge goes all the way back down below c. once i stop again and let it sits, it goes back to normal operating temp. anyone have any ideas would help me out alot. thanks
Old Mar 9, 2008 | 05:49 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: having temperature issues with the teg (dumada9)
You have a bad thermostat.
Old Mar 9, 2008 | 07:12 AM
JDM-Riders's Avatar
Default Re: having temperature issues with the teg (Dogginator)
Thermostat... Not too bad replacing it; 30 minutes or less. I need to change mine too..
Old Mar 9, 2008 | 08:22 AM
lmike6453's Avatar
yea the first time i did it i had a hard time locating it without a manual to help me...pm me if you need help
Old Mar 9, 2008 | 10:51 AM
BoSox46GSr's Avatar
Default Re: (lmike6453)
Thermostat, fairly quick fix, just use gear wrenches, because theres one bolt there with very limited room. You could be there for days without em'!
Old Mar 9, 2008 | 12:56 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (BoSox46GSr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoSox46GSr &raquo;</TD></TR><TR><TD CLASS="quote">Thermostat, fairly quick fix, just use gear wrenches, because theres one bolt there with very limited room. You could be there for days without em'! </TD></TR></TABLE>
I loosened the starter and used swivel sockets to get at the thermostat housing bolts. OP, if you do not have a manual get one. You will need to drain and refill the coolant.
Old Mar 9, 2008 | 01:02 PM
goota's Avatar
what size is that bolt? that bosox46gsr is talking about?
Old Mar 9, 2008 | 01:24 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (goota)
I recall 10mm. COuld be mistaken.
Old Mar 9, 2008 | 01:29 PM
UmbraDc2K's Avatar
Default Re: (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">I recall 10mm.</TD></TR></TABLE>
I'm pretty sure on that because nothing really gets much smaller than 10mm, well at least on the motor.
Old Mar 9, 2008 | 04:10 PM
easybake's Avatar
same thing happens to me. i have one i just habn't changed it yet. been to cold.
Old Mar 9, 2008 | 04:33 PM
dumada9's Avatar
Default Re: (easybake)
thank you for all the help in such a short amount of time. luckily the car isnt overheating from the thermostat, i'll make sure to try to get that replaced and also to buy the manual. thanks alot guys
jdm_spoon_dc2
Nov 7, 2008 10:39 AM
project-boosteD
Dec 24, 2004 05:53 PM
Left_E
20
Aug 11, 2004 06:03 PM
zer0zer0 TypeR
Mar 15, 2004 09:35 PM
bimrpwr
Jan 10, 2004 01:03 PM
